DSub for Android
Re: DSub for Android
Postby daneren2005 » Fri Jun 06, 2014 10:14 pm
sdct989 wrote:I noticed that one of the change lists for a previous version of Android mentioned something about you fixing how DSub has been preempting Bluetooth connections. Is there any chance that you maybe didn't go far enough on this change?
I ask because I've noticed that DSub still preempts my other Bluetooth connected players every chance it gets. It doesn't matter what app I leave connected to my Bluetooth stereo, when it re-connects DSub will always take control. It's really annoying because I frequently have left off on a quieter app, then when DSub takes control it is blaring.
I've tried uninstalling and reinstalling DSub, and it didn't work. I'm currently running DSub version 4.6.4 on a Samsung Galaxy S4. Let me know if there is anything else that I can try or send you to help track this down.
I have a few things I want to try to see if it fixes the issue. Throw me a email and I can send you a test apk to see if they fix it or not.
Postby farrantch » Mon Jun 23, 2014 1:13 am
What happened to the select all songs from an artist?
farrantch
Postby daneren2005 » Mon Jun 23, 2014 2:01 am
Which one do you mean? Play all and show all both still seem to be there...
Postby wesssider » Tue Jun 24, 2014 3:35 am
What will it take to incorporate 'batch mode' delete (+ others actions?) into the Now Playing list? I've dreamed of this feature since 2012:
viewtopic.php?p=46231#p46231
viewtopic.php?p=62164#p62164
wesssider
Postby ar9 » Thu Jun 26, 2014 2:09 am
Two new issues with 4.7.
1) Formatted my phone, installed DSub. Was presented with "Wrong username and password" persistent notification box. I don't know how I got around it, just clicked around for a while.
2) Now, for whatever reason (this is the reason I formatted my phone... probably shouldn't have), sometimes when I click "Cache" or "Permanent Cache", nothing will happen, it will blink as if I clicked it but it will just go back to normal and hang on that list screen... then I click it again and the list goes away but it doesn't actually do my command. Pretty annoying.
ar9
Postby interr0bangr » Thu Jun 26, 2014 4:14 am
Any chance of adding a tab that lists only the cached albums? I have several thousands of artists in a single folder and it's hard to remember what I've previously cached before without slowly going down the massive list. Basically hoping that it would operate like the "starred" filter only with cached/local files being displayed.
interr0bangr
Postby daneren2005 » Thu Jun 26, 2014 5:41 am
ar9 wrote:Two new issues with 4.7.
1) Should already be fixed. Was an issue where a wrong username/password would throw that error dialog. Issue was compounded by the demo server default user seeming to have been deleted.
2) Is it consistent? When you are trying to cache individual songs, or select an album to cache.
interr0bangr wrote:Any chance of adding a tab that lists only the cached albums? I have several thousands of artists in a single folder and it's hard to remember what I've previously cached before without slowly going down the massive list. Basically hoping that it would operate like the "starred" filter only with cached/local files being displayed.
Use the offline mode.
Postby ar9 » Thu Jun 26, 2014 5:44 am
Everything is fixed in 4.7.1
Another issue I'm having with Playlists.
When I go to add a song to a playlist I have synced and cached, it doesn't show up in the "Add to Playlist" list.
EDIT: Also, sometimes when I cache an entire album, I don't get the coloured thumb tack beside the album to show it's cached. Not a big deal, but sometimes hard to browse while online (but with minimum data).
ar9
Postby daneren2005 » Thu Jun 26, 2014 2:14 pm
What server version are you using? I added something to hide playlists you shouldn't be able to add to anyways, but I might have been overzealous for different versions.
Postby hawkinsb » Thu Jun 26, 2014 2:30 pm
With 4.7.1, I'm now getting an almost immediate crash when the app starts up in Online mode. Offline appears to be fine. Was previously running 4.7 with no issues... Connection test to the server succeeds. Ideas?
hawkinsb
Postby daneren2005 » Thu Jun 26, 2014 2:39 pm
Are you using a Gingerbread phone?
Postby hawkinsb » Thu Jun 26, 2014 3:16 pm
daneren2005 wrote:Are you using a Gingerbread phone?
Yes...
hawkinsb
Postby daneren2005 » Thu Jun 26, 2014 3:37 pm
Yes...
Alright, I used a method I hadn't realized didn't exist for older phones. I'll be doing a update when I get home from work to fix the issue.
Postby ecd1973 » Thu Jun 26, 2014 3:47 pm
farrantch wrote:Small feature request here..
When an artist is selected, there is the option to 'Show all media'. First of all, thank you for including this! No other app or webplayer has this feature that I know of.
I can't find this option any where. This may help with my previous issue of listing all songs by artist...
ecd1973
Postby farrantch » Fri Jun 27, 2014 3:07 am
Yeah it's not there anymore. Dunno what happened to it. Would really like it back.
farrantch
Return to DSub for Android
