DSub for Android
Re: DSub for Android
Postby ecd1973 » Fri Jun 27, 2014 12:53 pm
farrantch wrote:
I can't find this option any where. This may help with my previous issue of listing all songs by artist...
Yeah it's not there anymore. Dunno what happened to it. Would really like it back.
I found it this morning.
1. Click on Artist
2. List of Albums are visible. In the upper right click the ... button and you get the "Show All Media" option.
ecd1973
Postby farrantch » Fri Jun 27, 2014 10:38 pm
1. Click on Artist
Yeah, I used to have that. Not there anymore. Here's a screenshot http://imgur.com/1AsM5V8
farrantch
Postby rowolta » Sun Jun 29, 2014 10:16 am
It seems that DSub is not scrobbling to last.fm anymore. Have checked scrobble to last.fm in DSub. If I play from the web-interface it scrobbles. And it seems that the recently played data is not updated properly either. It is like DSub is playing from cache only, and no communication with the server.
rowolta
Postby daneren2005 » Sun Jun 29, 2014 3:56 pm
rowolta wrote:It seems that DSub is not scrobbling to last.fm anymore. Have checked scrobble to last.fm in DSub. If I play from the web-interface it scrobbles. And it seems that the recently played data is not updated properly either. It is like DSub is playing from cache only, and no communication with the server.
What server are you using since now it auto detects if it's setup on the server and they might not all be setting it correctly
Postby rowolta » Sun Jun 29, 2014 10:14 pm
Its Subsonic 5.0.beta1 (build 4046) – May 24, 2014
rowolta
Postby daneren2005 » Sun Jun 29, 2014 10:24 pm
Can you look on the admin tab and make sure it is set to enabled?
Postby rowolta » Mon Jun 30, 2014 7:09 am
In subsonic server (web-gui) Settings -> Personal -> "Register what I'm playing at Last.fm is checked". If I play from the web-gui it scrobbles.
In DSub Settings -> Playback -> "Scrobble to last.fm" is checked. In DSub Admin -> admin -> "Scrobbling allowed" is checked too". No scrobbles are sent to last.fm from DSub
rowolta
Postby daneren2005 » Mon Jun 30, 2014 2:11 pm
Then I'm not sure. Can you send me a log after you finish a song so I can see if it's throwing a error in the background?
Postby gamezonline » Mon Jun 30, 2014 2:35 pm
Still in love with your app, just got one request can you please add the ability to make dsub the default streaming/media player and also maybe integrate it with Google now
gamezonline
Postby rowolta » Tue Jul 01, 2014 7:46 am
daneren2005 wrote:Then I'm not sure. Can you send me a log after you finish a song so I can see if it's throwing a error in the background?
Sent the log through the app (to the predefined email). Forgot to mention the song that was played was "urfaust". There are no entries in the server log.
rowolta
Postby lamor » Tue Jul 01, 2014 3:02 pm
Since the update 4.7 (I think) of Dsub I noticed the automatic widget on the lockscreen doesn't disappears when play stop, for exemple when the bluetooth of the car stop.
And into the library, the albums names are the directory names.
Before the update they were the tag names even if we don't choose to browse by tags.
I prefer browse by folder scructure but it's better when the names of albums display by tags.
It's normal ?
lamor
Postby daneren2005 » Tue Jul 01, 2014 3:36 pm
lamor wrote:Hi,
It's normal ?
1) The lockscreen widget has never disappeared after playing stop until you open the lockscreen. This has been the default Android behavior since the standard music lockscreen widget was introduced in Android 4.0.
2) The problem is that when you update the album tags afterwards it doesn't update the album name for the album itself, meaning that it's impossible to fix bad data after it's first added.. I kept getting people with problems relating to that so I had to change it back to using the directory name.
Postby joost » Sun Jul 06, 2014 7:35 pm
Using d-sub for the first time, very Nice app! 2 suggestions:
- can you create an option not to go direct to the now playing screen when playing a song?
- the app icon is really shabby haha
The rest is just perfect!
joost
Postby gaui » Thu Jul 10, 2014 9:55 pm
gaui wrote:I always have to force stop the app, otherwise the lockscreen always displays music art and controls. Is there some way to fix this?
Sent from my SM-G900F using Tapatalk
When I stop the music, the lockscreen still has the album art. I have to force stop the app so it goes away.
KitKat 4.4.2 Samsung Galaxy S5
See here:
http://i.imgur.com/Ha2FqXn.jpg
gaui
Postby ar9 » Sat Jul 12, 2014 8:51 pm
4.4.2:
Cannot fast scroll when I try to slide down the right side of the screen.
ar9
Return to DSub for Android
