ar9 wrote:4.4.2:
Cannot fast scroll when I try to slide down the right side of the screen.
Info at viewtopic.php?f=2&t=14514#p63509, fix should be in next release
ar9 wrote:4.4.2:
daneren2005 wrote:ar9 wrote:4.4.2:
gaui wrote:daneren2005 wrote:ar9 wrote:4.4.2:
Why don't you reply to me?
rowolta wrote:In subsonic server (web-gui) Settings -> Personal -> "Register what I'm playing at Last.fm is checked". If I play from the web-gui it scrobbles.
In DSub Settings -> Playback -> "Scrobble to last.fm" is checked. In DSub Admin -> admin -> "Scrobbling allowed" is checked too". No scrobbles are sent to last.fm from DSub
moonman wrote:rowolta wrote:In subsonic server (web-gui) Settings -> Personal -> "Register what I'm playing at Last.fm is checked". If I play from the web-gui it scrobbles.
I've noticed the same issue. It used to work until recently. It says "successfully synced _ songs" when I go online, but they don't actually get scrobbled. Does work when I use the app in online mode though.
courtneecupcakes wrote:I think I found a bug. I'm on version 4.7.3, attempting to use Tasker to pause music, but the simulated pause/play button press only opens my stock player, regardless of the "media buttons" option checked. This does work, however, in the original subsonic app.
daneren2005 wrote:courtneecupcakes wrote:I think I found a bug. I'm on version 4.7.3, attempting to use Tasker to pause music, but the simulated pause/play button press only opens my stock player, regardless of the "media buttons" option checked. This does work, however, in the original subsonic app.
I'm adding a Tasker plugin in the next release...
mikes wrote:Try Media Button Router from the play store, it can direct media directives to the app of your choice.
Menk79 wrote:Hi! I've been using DSub for a long time and it's by far the best and most used app on my phone. However I have encountered a couple of minor problems. Firstly as of some time ago I'm no longer able to scrobble to Last.fm. Scrobbling works when I play a song in the Subsonic web-interface, but thru Dsub I get nothing in the Subsonic log. The strange thing is that scorbbling thru Dsub seems to work on my test server running 4.9, but not on my main server that is on 4.5. I have also tried to reinstall Dsub on my phone, but that didn't help.
