williamkray wrote:daneren2005 wrote:Podcasts should definitely be auto bookmarked, but others include songs over 10 minutes, and songs with the genre of AudioBook. It only creates a bookmark if you are more than 5 seconds into it. It should be being created when you remove the podcast from play. Can you try playing a podcast from the Podcasts tab, seek to the middle of it, then use Remove All from the menu. It should create a bookmark automatically then. If it doesn't, what server are you using?
ah, got it. i suppose i haven't come across that particular situation just yet. thanks for clarifying, just tested and everything works like a charm!
What exactly are you doing where you expected it to work?
