DSub for Android
Re: DSub for Android
Postby daneren2005 » Sun Sep 09, 2012 7:14 pm
bry wrote:Thanks for the quick fix and the lock screen widget. Would it be possible to add the ability to save playlist files locally?
Sent from my DROID RAZR using Tapatalk 2
They are already being saved locally automatically. If you go offline after looking at a playlist it will show up. I'm working on making this better but it will be some time as there are some other things I need to finish first.
Postby adriang » Mon Sep 10, 2012 3:46 pm
I use DSub to listen to audiobooks and podcasts, so I would really like to see 30s rewind/advance buttons for those times when you miss something that was just said. Trying to navigate an audio file using the slider is pretty rough in general and doesn't provide the precision you would need to move back or forward for small increments. If you really wanted to make the feature usable, you could add advance/rewind buttons and make the increment configurable.
adriang
Re: DSub for Android Playlist Error:
Postby adriang » Mon Sep 10, 2012 4:58 pm
I'm getting the following error when selecting one of my playlists:
Error Message:
"Resource not found. Please check the server address."
Name of playlist:
What I'm Listening To Now :)
Number Of Songs In Playlist:
22
This playlist works fine when using Subsonic for Android as well as the native web application.
adriang
Postby daneren2005 » Mon Sep 10, 2012 6:09 pm
adriang wrote:I'm getting the following error when selecting one of my playlists:
Error Message:
Name of playlist:
22
1) Is it only one playlist you are having trouble with?
2) Did you just start having trouble with it with this latest update or has it always been a problem?
Postby bry » Thu Sep 13, 2012 11:34 am
bry
Postby daneren2005 » Fri Sep 14, 2012 9:21 pm
I put it on the todo list but to be honest it's going to be fairly low on the priority list
Postby tmwsiy » Fri Sep 14, 2012 10:01 pm
How about chat and "now playing"?
Sent from my SGH-T999 using Tapatalk 2
tmwsiy
Postby daneren2005 » Sat Sep 15, 2012 12:26 am
tmwsiy wrote:How about chat and "now playing"?
Chat tab I would say is medium priority, but what do you mean by Now Playing? Is there anything specific you want from it different?
Re: Re: DSub for Android
Postby JMilesT » Sat Sep 15, 2012 12:46 am
adriang wrote:I use DSub to listen to audiobooks and podcasts, so I would really like to see 30s rewind/advance buttons for those times when you miss something that was just said. Trying to navigate an audio file using the slider is pretty rough in general and doesn't provide the precision you would need to move back or forward for small increments. If you really wanted to make the feature usable, you could add advance/rewind buttons and make the increment configurable.
Slide your finger up or down the album art while your audio is playing. The program will skip forward 30 seconds or go back by 8 seconds.
Sent from my ADR6425LVW using Tapatalk 2
JMilesT
Postby tmwsiy » Sat Sep 15, 2012 1:04 am
daneren2005 wrote:Chat tab I would say is medium priority, but what do you mean by Now Playing? Is there anything specific you want from it different?
Sorry, I should have specified: Showing "Now Playing" of all users- I think iSub has this feature. I have a few dozens users and really enjoy being able to see what others are listening to.
thanks again.
tmwsiy
Postby daneren2005 » Sat Sep 15, 2012 3:41 am
thanks again.
Ah alright. It's pretty low priority as well but a lot of when it would get done would depend on how difficult it would be to implement.
Postby ghost5 » Sat Sep 15, 2012 11:23 am
This app needs some ui changes in landscape mode when browsing songs.
(I know that this problem exists for nearly every program in landscape mode when working with lists)
At the moment I can only see 2 songs at a time when browsing which isn't very use able.
My solutions are to
change the buttons at the bottom from writing to symbols, that way pin, select all, play last etc all fit on one row and three songs at a time can be viewed.
Split the list in half vertically so that 2 songs are shown on one line, this way 4 songs are shown at the same time.
Our do a combination of both so that 6 songs are shown at the same time.
I would also like to be able to flick between the different tabs which is now very common in android apps.
Cheers
Sent from my Nexus 7 using Tapatalk 2
ghost5
Postby skidelo » Mon Sep 17, 2012 5:39 am
Looks promising!
2 feature requests/suggestions:
1) DLNA Support (similar to airplay on iSub)
2) Manual caching of songs (for airplane, etc. - also on iSub)
Glad to see someone has picked up android development. Keep up the good work.
skidelo
Postby daneren2005 » Tue Sep 18, 2012 5:32 pm
ghost5 wrote:This app needs some ui changes in landscape mode when browsing songs.
My solutions are to
Cheers
Yah the entire download tab needs to be re-worked. It won't be in this upcoming update, but I will try to get it in the next one. I so rarely even have rotate on that I didn't even realize it was a problem until you said something.
skidelo wrote:Looks promising!
1) DLNA has API support on iOS which makes it easy to implement. I'm not sure how simple it would be to do on Android but I will take a look into it.
2) I'm currently working on better caching of songs because yes right now it sucks. You basically just need to go in a add everything you want cached to the playlist.
Postby bry » Wed Sep 19, 2012 8:29 pm
On the primary home screen when launching dsub can you add an "offline" category so I dont have to change the server to offline mode?
bry
Return to DSub for Android
