Muting of music for notifications
Postby ghost5 » Sun Nov 11, 2012 3:10 pm
I noticed a couple of released back that d sub now pauses the music when a sat nav notification comes through and then resumes playback. This was a much requested feature so thanks.
As I have a speed camera app that runs all the time this becomes annoying due to the constant pausing / resuming of the music.
Can I request that instead of pausing the music that the volume is turned down to around 70% volume, or add an option to turn this feature off all together.
Cheers
Sent from my Nexus 7 using Tapatalk 2
ghost5
Re: Muting of music for notifications
Postby daneren2005 » Sun Nov 11, 2012 4:56 pm
Sure I'll look more into it. Honestly the reason I did pause instead of lowering the volume was because I couldn't quickly figure out how to lower the volume and I just forgot to back and fix it.
Postby GJ51 » Sun Nov 11, 2012 7:10 pm
daneren2005 wrote:Sure I'll look more into it. Honestly the reason I did pause instead of lowering the volume was because I couldn't quickly figure out how to lower the volume and I just forgot to back and fix it.
I like pause. The older you get, the less multi-tasking you do. :wink:
Postby daneren2005 » Sun Nov 11, 2012 7:38 pm
Hmm, so maybe it would be better to give an option for it. I'll look into it
Postby ghost5 » Mon Nov 12, 2012 8:48 pm
Thanks. Lowering the volume would be better but I'd be happy with an option to just turn the pausing feature on or off.
ghost5
Postby dewd » Mon Nov 12, 2012 9:38 pm
I did not realize DSub handled this properly. I had asked the question in the main thread and I do not believe I got an answer (or more I more likely missed it).
Armed with this new knowledge I am now off to the Play Store to purchase DSub!!! :mrgreen:
dewd
Postby dewd » Mon Nov 12, 2012 9:40 pm
And BTW - I prefer the option to pause or lower. I actually like pause best but I can see when it would be beneficial to lower the volume instead. What I wouldn't like is having the volume lowering as the only option.
dewd
Postby dewd » Tue Nov 13, 2012 12:08 am
Purchased. Tested. It works. Done.
Uninstalling Subsonic, Google Music, and Power Amp. I have now have one app that 'just works'. :D
dewd
Postby daneren2005 » Tue Nov 13, 2012 12:57 am
The option for either pause or lower volume is now there and ready to go for the next release. And if you care about gapless playback you might want to keep PowerAmp installed since I haven't figured it out yet ;)
Postby ghost5 » Fri Nov 16, 2012 4:53 pm
Thanks.
... Now I just need to figure out why my subsonic service keeps crashing so I can use d sub again
ghost5
Postby dewd » Tue Dec 04, 2012 9:14 pm
I finally got a chance to test the 'lower volume' option with Google Nav and DSub. Unfortunately, when the volume lowers it also lower the Google Nav volume and I cannot hear the instructions.
The option to pause still works perfectly.
I have not tested DSub with CoPilot Live yet. I suspect it will work better since CoPilot uses its own volume controls.
dewd
Postby daneren2005 » Tue Dec 04, 2012 10:09 pm
Right you are. I just looked and it looks like I stupidly set it to lower the stream's volume instead of the individual media player's volume. I'll definitely fix it for you :D
Return to DSub for Android
