Possible to shuffle by music folder or genre?
Postby Blindfish » Sat Nov 24, 2012 4:11 am
I'm new to Subsonic and DSub and am still experimenting and learning my way around. Is it possible to shuffle songs only from my "music" folder? When I press the shuffle button on my phone I get songs as well as TV shows, radio broadcasts and movies in my "playing" list. Can I limit the shuffling to only the "music" or other selected folder?
Secondly, is it possible to shuffle music based on genre only? I'd like to select "jazz", for example, and be able to shuffle within that genre of music. Currently I'll get jazz, heavy metal, classical or whatever all mixed in together and it can be quite jarring sometimes to hear something not quite in the same mood as the previous few songs.
Blindfish
Re: Possible to shuffle by music folder or genre?
Postby daneren2005 » Sat Nov 24, 2012 5:36 am
For DSub yes the shuffling is based off of whatever root folder you have selected. On subsonic it is not. And sadly I haven't quite gotten around too genre based shuffling but it is in the works and I would expect it sometime in the next month
Sent from my Nexus 7 using Tapatalk 2
Postby mr_nobody » Sat Nov 24, 2012 3:01 pm
In addition to shuffle by genre, year would be good too.
mr_nobody
Postby daneren2005 » Sat Nov 24, 2012 3:39 pm
Yep, the API supports year ranges and genre so I am thinking I will add support for those two. I can't really do anything else without additional API support though.
Postby Blindfish » Tue Dec 04, 2012 2:53 am
I had a further thought about this. Is it or would it be possible to shuffle based on multiple genres, e.g. "jazz", "blues" and "vocalese" and have songs based on these three selections. Alternatively, if I were to have multiple genres in the MP3's ID tag could/would DSub be able use them and select tunes accordingly?
Blindfish
Postby daneren2005 » Tue Dec 04, 2012 4:17 am
Blindfish wrote:I had a further thought about this. Is it or would it be possible to shuffle based on multiple genres, e.g. "jazz", "blues" and "vocalese" and have songs based on these three selections. Alternatively, if I were to have multiple genres in the MP3's ID tag could/would DSub be able use them and select tunes accordingly?
I'm just using this Subsonic API. I doubt it supports multiple genre's and I don't know how it handles multiple genre's in the id tags. The update is already out for it so you can just try it out :D
Postby Zooey22 » Wed Dec 05, 2012 12:36 am
Hi, it looks like this got implemented in the last update? I went to do my usual ramdom shuffle and a box popped up wanting to know parameters to shuffle by. My music is not that well tagged so for me, this breaks Dsub. May i have just the random shuffle back??
s
2,363 artists
11,276 albums
89,187 songs
1030.93 GB
6,936 hour
Zooey22
Postby daneren2005 » Wed Dec 05, 2012 12:40 am
Just click ok...you don't have to enter anything. They aren't required fields.
Postby Zooey22 » Wed Dec 05, 2012 12:47 am
I did that but then Dsub didnt load anything onto the now playing, Ill check again real quick.
yeah goes to now playing and says playlist is empty
Subphonic still shuffles
2,363 artists
11,276 albums
89,187 songs
1030.93 GB
6,936 hour
Zooey22
Postby daneren2005 » Wed Dec 05, 2012 12:59 am
Hmm I just tried it from a fresh install and it works fine for me. Did you try giving it a second? Sometimes it takes a second to start returning data for me.
Postby Zooey22 » Wed Dec 05, 2012 1:05 am
Just did a reboot and now its fine, Oi, sorry to bother you :-\
tho my ics lockscreen widget still doesnt show lol
Thanks for your time
s
2,363 artists
11,276 albums
89,187 songs
1030.93 GB
6,936 hour
Zooey22
Postby daneren2005 » Wed Dec 05, 2012 1:06 am
Zooey22 wrote:Just did a reboot and now its fine, Oi, sorry to bother you :-\
s
Curious, did you do a reboot of the phone, app, or server? I'm wondering if somehow you got stuck in a state where the shuffle buffer wasn't being filled properly. Let me know if it happens again.
Postby Zooey22 » Wed Dec 05, 2012 1:37 am
rebooted that phone, i should know to think of that first. Shuffle buffer problem seems right, could have been Link2sd that was blocking it as I use that to keep my apps on sd card .\Thanks again
s
2,363 artists
11,276 albums
89,187 songs
1030.93 GB
6,936 hour
Zooey22
Postby norcalscott » Tue Dec 25, 2012 8:44 pm
Hello, I have recently set up Subsonic and most everything is working well. I have also purchased DSub for three different devices / users and am very happy with the application. However, I am having the same issue reported in this thread concerning Random playlists not working. When I select Random, a list of random tracks does appear, but when I select Play at the top of the screen, I just get an empty playlist.
- I am running the latest version of Dsub and of Subsonic on the server
- All my mobile devices are running Jelly Bean
- All devices exhibit the above behavior
- I tried rebooting the devices and rescanning the media folders in Subsonic
- My Subsonic server is not yet licensed, would that have an impact on this?
I also noticed where some users reported that a drop down list of additional random choices (by genre, etc) appears. That doesn't happen on my devices either - is that something that was taken out of this latest release?
Thanks for any help you can give me with this issue, which would make this a perfect replacement for Audiogalaxy.
norcalscott
Postby daneren2005 » Tue Dec 25, 2012 10:25 pm
The random albums not being able to click play all is a different issue from the one the other user was reporting. Someone just reported the issue you are having the other day and I will look at it. I guess I never try to play all random albums. I usually use the shuffle all function from the main screen or I go down to a random album and play a single album and both those work.
As for the second issue I haven't heard anyone else getting the set of extra options intermittently. Are you sure you are pressing the same shuffle icon on the same tab on all devices. For example pressing shuffle on the now playing tab won't bring up the menu it just shuffles the now playing list. Try pressing the shuffle icon on the first tab in Dsub to see if you only get the menu on some.
Return to DSub for Android
