[feature request] advanced "screen on" settings
Postby wikke » Tue Nov 27, 2012 10:31 pm
There is already a "screen on" option in the 'now playing' tab. It's very handy whilst driving for example.
Unfortunately, this has to be enabled every time you want to leave the screen on.
Would you mind considering adding this to the settings?
I suppose it depends on a few variables whether users would want that.
Like when connected to power, wifi and/or bluetooth.
Many persistent apps (like syncing apps) use this kind of "power-saving" schemes.
thanks for your time
wikke
Re: [feature request] advanced "screen on" settings
Postby daneren2005 » Tue Nov 27, 2012 10:49 pm
Would whichever one you set being left on until you switch be satisfactory? I am trying to avoid adding things to the settings menu unless absolutely necessary. Feature creep is a nasty mistress.
Postby wikke » Wed Nov 28, 2012 9:22 pm
A toggle would indeed already fix the problem! The rest are just luxuries ;-)
thanks
wikke
Return to DSub for Android
