[Bug] DSub has stopped unexpectedly
Postby rubbersoul » Sun Dec 09, 2012 8:42 pm
I'm noticing two bugs in DSub. One occurs occasionally when I launch the app from the widget by pressing the album art. An error message will pop up stating that the app has stopped. Usually when I relaunch the app, it starts working.
The other bug I noticed has to do with the theming. I have the holo theme enabled. Whenever I first launch the app, the DSub title-bar with a blank screen shows up while the app is loading. This load screen is still showing the light theme despite the rest of the app being in holo theme. Minor bug, but figured I'd let you know about it.
rubbersoul
Re: [Bug] DSub has stopped unexpectedly
Postby daneren2005 » Sun Dec 09, 2012 9:15 pm
You can still manually set the theme, before the light theme was just the default. I went ahead and changed it to default to the Holo theme for the next release though. Have you submitted the crash report so I can look at it?
Postby rubbersoul » Mon Dec 10, 2012 2:30 pm
I have sent them a few times. I will send it again when it happens
rubbersoul
Postby daneren2005 » Tue Dec 11, 2012 12:46 am
I've fixed several crashes that have been submitted to me. I'm just sitting on them until after I can figure out some other stuff. If you reported it chances are I already fixed it :D
Return to DSub for Android
