[Feature Request] Enhancements to lock screen widget
Postby rubbersoul » Sun Dec 09, 2012 8:49 pm
On the homescreen widget, when the album art is pressed the app is launched. It would be nice to have the same functionality with the lockscreen widget because it would speed up the process of changing what I'm listening to or adding more music to the playlist.
The other enhancement I would like to see is the lockscreen widget to load automagically when something is plugged into the headphone jack. I saw another feature request for automatically starting the music, but this may not be desired in all situations. if the lockscreen widget is loaded instead, you could start the playback without unlocking the screen which would be very fast without doing something the user didn't explicitly for.
rubbersoul
Re: [Feature Request] Enhancements to lock screen widget
Postby daneren2005 » Sun Dec 09, 2012 9:33 pm
Unfortunately I only use the standard music lockscreen api so I can't really add a click handler to the lockscreen widget without redesigning it from scratch. As for the showing the lockscreen widget, I can look at how to just show it without starting the music and try adding it as an option.
Postby rubbersoul » Mon Dec 10, 2012 2:31 pm
Yeah, I was wondering if that would be outside the realm of the api. Thanks for looking into it and the fast response!
rubbersoul
Return to DSub for Android
