Dsub Changing Tracks
Postby gomer23 » Mon Dec 24, 2012 7:54 pm
I found Dsub today and bought and installed it so the metadata would play on my new bluethooth enabled car stereo. I have been having some force close issues with it however.
What is happening is if I use the widget, or notification window to change tracks sometimes it will jump 2 or 3 songs on single press. I will then try to backup to the song I wanted and the app will freeze and force close. This will also occur in my car using the radio to skip a track or backup a track. Changing tracks from within the app is much more stable.
My phone is a Motorola Razr Maxx with a custom ICS rom installed on it. Right now I have Dsub configured to use my external SD card for cache storage but I did try to replicate this issue with the default location and the same symptoms occured.
Let me know what else I can try.
Thank you for a great app!
gomer23
Re: Dsub Changing Tracks
Postby gomer23 » Mon Dec 24, 2012 8:00 pm
This log should contain the information during the force close.
gomer23
Postby daneren2005 » Wed Dec 26, 2012 10:23 pm
I should already have the force close fixed, but I'm still trying to track down the source of the skipping tracks.
Postby gomer23 » Thu Dec 27, 2012 2:08 pm
If you need any other information from my phone let me know. I did return the phone back to stock just for kicks and the same symptoms occurred.
gomer23
Postby daneren2005 » Thu Dec 27, 2012 3:20 pm
Are you still having the same issues after the latest update? If so can I get another round of logs because at the very least the errors that I thought were the cause won't be in there anymore so it will be easier to look for another cause.
Postby gomer23 » Thu Dec 27, 2012 4:43 pm
Moments after I commented back to you this morning, I saw your update get pushed through. All seems to be working thus far! Been loving your app prior to this bugfix and now this makes using this in my car much easier! Keep up the great work.
gomer23
Return to DSub for Android
