Feature Request: Make playlist visible to other users
Postby thelazy8 » Thu Jan 10, 2013 7:19 pm
Whenever I make a new playlist on dsub, it is by default not visible to other users. This is fine, but if I want to make a playlist to share with my wife, I then have to go to the web client and edit the playlist to check the box "Make this playlist visible to other users" in order for that playlist to show up for her. Can this checkbox be added to the "update information" dialog when you long-press on a playlist?
thelazy8
Re: Feature Request: Make playlist visible to other users
Postby daneren2005 » Thu Jan 10, 2013 8:04 pm
Right now I do not believe there is any way to update that value with the Subsonic API. You can check here: http://www.subsonic.org/pages/api.jsp but I looked and didn't see anything that would support it. What I can do is put in a request to Sindre and see if it gets put in in a future version of Subsonic.
Postby newburns » Fri Jan 11, 2013 7:17 pm
I second this request. I use Subsonic for events, and playlist are created by event coordinators, but even I, the administrator can't see them until they make the playlist public.
newburns
Postby daneren2005 » Thu Jan 17, 2013 3:54 pm
Just kidding. Sindre claims that it is already there he just forgot to add it to the documentation. I will have to try to add it for the next version for you guys :D
Postby thelazy8 » Sun Jan 27, 2013 5:34 am
Awesome. Thanks!
thelazy8
Return to DSub for Android
