ServerTooOldException
Postby NiffStipples » Mon Jan 21, 2013 1:37 am
Hey guys,
i'm getting a weird exception when i try to add songs to an existing playlist - the app always gives me an "ServerTooOldException" Exception.
I'm on the latest MusicCabinet release and also at the latest dsub version - so i've got no clue where the issue could be :/
Maybe someone has a good advice for me? Thanks in advance! ;)
NiffStipples
Re: ServerTooOldException
Postby daneren2005 » Mon Jan 21, 2013 2:53 am
That probably means that the server is not sending the correct server version. I check the REST API version to make sure that it will work. They might not have either added the API or maybe just didn't change the version number.
Postby hakko » Mon Jan 21, 2013 6:08 am
How do you check the version, just using what is returned in getLicense? What is mandatory from 1.8.0?
MusicCabinet developer
hakko
Postby daneren2005 » Mon Jan 21, 2013 5:14 pm
It looks like the code just caches the version from a previous response. It looks like the version is sent in every response (I'm not too sure, I am just using the original code for that)? And yah according to http://www.subsonic.org/pages/api.jsp#updatePlaylist it is mandatory 1.8.
Postby NiffStipples » Tue Jan 22, 2013 10:01 am
Wow, both devs at my thread :D
So, can i change anything on my configuration to get it working or is the fault somewhere else?
NiffStipples
Postby hakko » Tue Jan 22, 2013 11:06 am
Nah, you're out of luck until I make MusicCabinet completely compatible with Subsonic 4.7 (right now it is somewhere between 4.6 and 4.7). Sorry about that.
(Or add it yourself! it's open source)
hakko
Postby NiffStipples » Tue Jan 22, 2013 2:10 pm
Uh, i would if i could - but i think i'll better keep waiting for your update ;)
Thanks a lot! :)
NiffStipples
Return to DSub for Android
