Play buttons missing
Postby Chorca » Wed Jan 23, 2013 2:41 pm
I just purchased Dsub yesterday, and it worked spectacularly that night, played great, everything.
This morning when I tried to add some files to the playlist via the app, I found that when I selected files in the library view, the buttons that usually pop up from the bottom did not come up. I tried going back and forth through menus and exiting the app via the exit command and going back into it, but I could not get the buttons to come back up.
I also noticed that while the bluetooth title streaming worked great last night, this morning none of the titles were being reported to my radio.
I'm including a screenshot, and the issue is currently happening, so if there is any more info needed, I can help grab that.
Chorca
Re: Play buttons missing
Postby daneren2005 » Wed Jan 23, 2013 3:08 pm
I personally thought all those buttons at the bottom were:
1) Impracticable to have to scroll to the bottom to use
2) Ugly as Hell
3) Not easy to add to as I added functionality and wanted to add more.
So I moved everything into the main menu. One thing to note that the Play, shuffle, download, cache, delete, and play last options have an implicit select all. If you select nothing instead of just not being usable like they were in Subsonic, it now assumes that that means you want to actually apply those actions to everything currently displayed. So for example I rarely actually select anything, I usually just go into the album I want to play and press play or play last depending on which I wanted.
Return to DSub for Android
