DSub 3.7.0 Released, DSub 3.7.2 with Android 2.2 fix
Postby daneren2005 » Fri Jan 25, 2013 3:58 am
Nothing major, just a couple of fixes for issues people have reported as well as a bunch of minor features people have requested the last few months.
Changelog:
Buffer Length option - set it to 0 if you want to not play files until finished downloading
Cache album art in same folder so 3d party apps can display it
Playlist info - see if it's public or not (4.7+)
Playlist update - change if it's public or not (4.7+)
Keep aspect ratio of album art in landscape mode
Improved offline search (matches whole words + sorts by relevance)
Added delete option to artist/album long press menus
Fixed shuffle sometimes not working
Fixed cache not working
Re: DSub 3.7.0 Released
Postby mr_nobody » Fri Jan 25, 2013 1:33 pm
daneren2005 wrote:Buffer Length option - set it to 0 if you want to not play files until finished downloading
Looking forward to testing this. Thanks!
I'm guessing this was easier to implement than all of the other work you already did messing around with the buffering issues. :(
mr_nobody
Postby daneren2005 » Fri Jan 25, 2013 3:12 pm
Oh yah. That took me maybe 30 minutes to an hour. But then again the only reason why I knew exactly where to look and what to change is because I had so recently just examined and rexamined the guts of that class already.
Postby daneren2005 » Fri Jan 25, 2013 3:24 pm
Some people were reporting that the shuffle was crashing for them so I reupdated 3.7.0 with a small fix.
Postby cyrus » Sat Jan 26, 2013 8:25 am
Updated to 3.7.0 on HTC Desire running Android 2.2.2. I'm currently experiencing a couple of issues:
1) in online mode I'm able to contact server and see library contents, but clicking on artist brings up java.lang.String.IsEmpty error
2) in offline mode, I can no longer see album art
Regards
cyrus
Postby mr_nobody » Sat Jan 26, 2013 3:28 pm
cyrus wrote:1) in online mode I'm able to contact server and see library contents, but clicking on artist brings up java.lang.String.IsEmpty error
Does this also happen on the test server or just your server? I'm not seeing this issue on my server.
mr_nobody
Postby cyrus » Sat Jan 26, 2013 4:44 pm
It's on the test server as well as my own server, but going back to 3.6.9 it all seems fine, so I'm reverting to that for now
cyrus
Postby daneren2005 » Sat Jan 26, 2013 5:51 pm
Sorry, I once again forgot that isEmpty wasn't supported until 2.3. Here is 3.7.1 which eliminates the use of isEmpty.
And you will have to browse to the folders again to redownload the album art because the location for it changed.
Re: DSub 3.7.0 Released, DSub 3.7.1 with Android 2.2 fix
Postby mr_nobody » Sat Jan 26, 2013 6:55 pm
I guess it will take a little while for 3.7.1 to show up in the play store?
mr_nobody
Postby daneren2005 » Sat Jan 26, 2013 6:58 pm
Usually a hour or two
Postby cyrus » Sat Jan 26, 2013 8:48 pm
OK - thanks, given 3.7.1 a try, but still get the IsEmpty error - on both the demo server and my own server. Any thoughts?
cyrus
Postby daneren2005 » Sat Jan 26, 2013 9:05 pm
Send me a log so I can see where you are getting the error. I probably just missed one somewhere.
Postby cyrus » Sat Jan 26, 2013 9:49 pm
Ok. Will reinstall and send log. Regards
cyrus
Re: DSub 3.7.0 Released, DSub 3.7.2 with Android 2.2 fix
Postby daneren2005 » Mon Jan 28, 2013 4:25 am
Ok I hope this is the last case of isEmpty. This is 3.7.2 with Android 2.2 fixed. Nothing else should be changed so it's not a big deal for others to update.
Postby cyrus » Mon Jan 28, 2013 9:13 am
Hi - this is much appreciated; all seems ok now . Thanks for sorting!
cyrus
Return to DSub for Android
