Bluetooth
Bluetooth
Postby pellinore » Fri Feb 08, 2013 4:33 pm
I'm having problems with getting bluetooth working. It works great with google music, samsungs stock app but what happens is when I try and play something with dsub, goolge music will play instead. I wondering if there is a setting in Android to make dsub the default bluetooth app?
pellinore
Re: Bluetooth
Postby odt » Fri Feb 08, 2013 7:17 pm
i have a similiar issue, but didnt manage to solve it yet.
odt
Re: Bluetooth
Postby daneren2005 » Fri Feb 08, 2013 7:22 pm
What do you mean when you "try to play". You mean that when you press the play button in Dsub it starts in Google Music instead?
Re: Bluetooth
Postby iwill » Fri Feb 08, 2013 10:22 pm
You could try to disable/uninstall Google Music.
iwill
Re: Bluetooth
Postby odt » Tue Feb 19, 2013 8:01 am
Some update on this. After moving away from the Sony stock ROM to Cyanogenmod I have managed to find a solution.
I have set up a macro using MacrDroid to automatically launch DSuB on BT media device connect, wait 3 seconds and then start the "Media:Play/Pause" activity, which this time seems to be picked up by DSuB. Great :)
odt
Re: Bluetooth
Postby quicky » Tue Mar 05, 2013 8:49 am
Same issue here... with DSub, and the original Android client.
The music starts playing for a few seconds and then my car says "Playback stopped" and the music stopped playing over bluetooth, however the client is still playing back. I simply can't here it anymore. So I guess the BT-stack resets.
It doesn't happen with any other player.
I'm using an Xperia Z
quicky
Return to DSub for Android
