[BUG] Library scroll bar blocks the "play" triangle
Postby iwill » Wed Feb 20, 2013 3:15 pm
I just noticed something odd. In the Library tab I can't click the play button (triangle in a circle) because the scroll bar is in the way. Obviously this isn't really a play button but that's just what I'm calling it because it brings up the menu to play, download, etc. Instead, it target scrolls to that point in the library list forcing me to long press on any of the library items that I'm interested in.
Just wanted to let you know - thanks!
iwill
Re: [BUG] Library scroll bar blocks the "play" triangle
Postby daneren2005 » Wed Feb 20, 2013 3:33 pm
Yah I've noticed that. Unfortunately I'm not really sure what to do about it since the scroll bar needs to be there so you can click it to quick scroll :(
Postby iwill » Thu Feb 21, 2013 2:47 pm
Could you not just re-position the "play" buttons to that they're to the left of the scroll bar? Either that or you could remove them since they're unusable at this point.
iwill
Postby rubbersoul » Thu Feb 21, 2013 4:36 pm
If you wait a sec, the scroll bar disappears and the button works. Otherwise you can always long press to get the same menu
rubbersoul
Postby daneren2005 » Thu Feb 21, 2013 4:39 pm
I will look into moving the button over so you can still click it, but yah I'm not going to remove it since it is useful if you wait a second for the scrollbar to disappear.
Return to DSub for Android
