[Bug] "Add to playlist" in Search Result-View not possible
Postby applican » Wed Mar 06, 2013 10:06 am
Hi
When long-tapping a song in the search-result-view i can click on "Add to playlist", but nothing happens afterwards (when I long-tap a song in regular library-view i can then select the playlist to add it to).
I tested this on a Galaxy Note 10.1, Android 4.0.4 and Nexus 4, Android 4.2.1; Both show the same behaviour.
It would be great if this issue could be fixed some time.
best regards, dave
applican
Re: [Bug] "Add to playlist" in Search Result-View not possib
Postby daneren2005 » Wed Mar 06, 2013 6:01 pm
Yah right now the search activity is completely separate from the other ones. I need to update all of the menus so that they actually work there as well.
Return to DSub for Android
