Feature Request: DSP Manager support
Postby msndebord » Mon Mar 25, 2013 5:49 am
Hi, I don't know if you are familiar with the XDA community or not, but a developer has made a sound mod that increases sound quite significantly and it uses DSP Manager, which at the moment DSub does not support. The thread is here: http://forum.xda-developers.com/showthr ... ?t=2059185 if you want to check it out. And if you were to add support I would definitely appreciate it.
msndebord
Re: Feature Request: DSP Manager support
Postby msndebord » Thu Mar 28, 2013 1:02 am
Nothing?.. You could do it the same way that google play music does their EQ, as that is compatible.
msndebord
Postby daneren2005 » Thu Mar 28, 2013 1:55 am
This has been discussed a bit in the huge main thread. I have removed every single reference to the EQ until it is actually being used, yet it is still being blocked. Unless you have an idea I have absolutely no idea what else I can do to not block DSP Manager. As Google Play Music isn't open source, I have absolutely no idea how they do their EQ or what the "same way" is.
Postby msndebord » Fri Mar 29, 2013 12:33 pm
Apollo works with it and it is also by CyanogenMod which is open source. Source code for them is here: https://github.com/CyanogenMod and for Apollo I believe it's here: https://github.com/CyanogenMod/android_ ... pps_Apollo
msndebord
Postby daneren2005 » Fri Mar 29, 2013 2:28 pm
Apollo doesn't have it's own EQ, does it? If it does, let me know where. I just installed it and don't see one anywhere. The problem is that the EQ in the app appears to be interfering with the 3d party EQ you are trying to use.
Postby msndebord » Fri Mar 29, 2013 3:09 pm
No, sorry I meant that Apollo works with DSP Manager and musicFX in the same way that Play Music does. If you go to the now playing screen and push the menu button or the 3 dot overflow onscreen it should be equalizer or sound effects. Also Power Amp supposedly has support, although I have not tried it.
msndebord
Postby daneren2005 » Fri Mar 29, 2013 4:07 pm
Alright, I will have to look at how it is done there and see if I can figure out how to fix it.
Postby msndebord » Fri Mar 29, 2013 4:13 pm
If you haven't yet I would go on XDA and ask for a little help, if needed, I know Subsonic is one of the favorable streaming services on there, so surely someone would be up for it.
Thanks for at least trying to fix it, I really appreciate it.
msndebord
Postby daneren2005 » Sat Apr 13, 2013 1:20 am
Does anyone want to test this with a third party DSP manager? One of the differences I found between players like Apollo is that they sent out a custom intent that I think I might be part of it.
Postby msndebord » Wed Apr 24, 2013 2:54 am
Holy crap, it works. Thanks man. Sorry I took so long, I hadn't checked this forum lately.
msndebord
Postby daneren2005 » Wed Apr 24, 2013 3:44 am
Sweet good to know. I wish stuff like that was better documented though lol.
Postby msndebord » Wed Apr 24, 2013 5:20 am
Yeah, sucks for devs like you, having to do extra work to fix it. Thank you for all of your hard work!
msndebord
Postby hauglien » Mon Feb 17, 2014 12:21 pm
Hi.
I have been using the apk supplied in this thread, but recently I bought DSub from Play store. Is there any reason that the DSP manager support is left out of the Play store version?
hauglien
Postby daneren2005 » Mon Feb 17, 2014 4:53 pm
They are the exact same thing... I literally upload the same apk to here and the play store
Return to DSub for Android
