Bug - Tracks not automatically skipping
Postby xran_deex » Mon Mar 25, 2013 7:52 pm
I tried to read all previous posts for this same problem, but I couldn't find any. I apologize ahead of time, if there is already an answer.
Back-story: I purchased Dsub from Google Play about a month ago. It worked fine. Then, I believe after an update, tracks all of a sudden stopped automatically skipping at the end of a song. I can manually skip a track, but dsub hangs at the end of any track. Thinking it was the update, I attempted to load an older version, but the problem persisted. I think the problem affected the default subsonic app, but I can't remember. I have installed 6 or 7 different versions of Dsub to no avail. So, I decided to re-flash my ROM (LiquidSmooth ICS on DroidX). I flashed 3 different versions. The problem still persists. Now, the default subsonic app works fine (tracks proceed to the next automatically). Dsub still won't skip. Dsub now has another problem. Downloaded/Cached songs will repeatedly download when they are finished. I don't know if that problem is related. Logcat doesn't seem to provide any clue.
Any ideas?
xran_deex
Re: Bug - Tracks not automatically skipping
Postby daneren2005 » Mon Mar 25, 2013 8:01 pm
If it just goes from working to randomly not working, even on older versions, my money is on the ROM...
Postby xran_deex » Wed Mar 27, 2013 3:08 am
I decided to flash a new rom. (I couldn't find much for my old Droid x.) Anyway, the problem seems to be fixed. Thanks for the reply.
xran_deex
Return to DSub for Android
