Battery Drain
Battery Drain
Postby jsonnabend » Sun Apr 28, 2013 2:10 pm
I am using an SIII with the special build of DSub. I am on JellyBean, I believe. I am getting severe batter drain. When I look at my battery usage, I see that "Media" (with a download arrow as an icon) is using most of the battery by a wide margin.
Is this the bug that was discussed in a different thread, and is there a fix? I'd hate to give up on DSub.
TIA
- Jeff
jsonnabend
Re: Battery Drain
Postby daneren2005 » Sun Apr 28, 2013 4:18 pm
1) What does "special build" of DSub mean?
2) Do you have root?
3) Yes it sounds like it is the same bug discussed in viewtopic.php?f=16&t=11923
Re: Battery Drain
Postby jsonnabend » Sun Apr 28, 2013 9:55 pm
I was referring to the build in the thread you cited. I thought that was a "special build" for the SIII issue. Anyway, that's the build.
I have root, but stock ROM.
Thoughts?
- Jeff
jsonnabend
Re: Battery Drain
Postby daneren2005 » Sun Apr 28, 2013 10:33 pm
Ah I see what you mean now. Did you only start having the issue after using the special build?
Re: Battery Drain
Postby jsonnabend » Sun Apr 28, 2013 10:38 pm
No, I had the issue with the earlier builds as well. It was particularly bad last night, though, the first time I used the new build.
- Jeff
jsonnabend
Return to DSub for Android
