Feature Requests
Re: Feature Requests
Postby daneren2005 » Thu May 23, 2013 11:40 pm
I will have to look more into how he went about implementing it.
Postby boognish43 » Mon May 27, 2013 4:58 am
HUGE thanks for adding the chat feature and all that you do with this app!
couple more requests/questions
1. is there a way to get the now playing to show what is currently playing and not what is currently downloading? Right now it will show you as listening to each track(on the web browser) when it downloads in your queue. I would like it to show what track your currently listening to instead
2. when I go into my starred items i get a list of the albums on top and tracks below. I cannot select any of the tracks to add to a playlist. I can click on the right arrow icon and play now but not select say 8 of 10 starred songs and add them.
boognish43
Postby daneren2005 » Tue May 28, 2013 3:56 am
1) That will require a change on the server side I think since it's just setup to consider each download as a play. I wish it would use the scrobble information instead, but it's not setup that way right now I don't think.
2) I don't think I am understanding you correctly. I just went to starred and I can select several songs and press play from the actionbar menu and it just plays them, or do any of the actions just fine. Am I missing something?
Postby rmnma » Fri Jun 07, 2013 12:25 pm
Is it possible to show the track number of an album before the songtitle?
rmnma
Postby daneren2005 » Fri Jun 07, 2013 4:14 pm
Sure, it shouldn't be that hard to add it as a option
Postby AbeFM » Tue Jun 18, 2013 8:44 pm
Two features, likely already done:
1) Path to store music should be browseable! I couldn't find my SD card, every time my memory was full it turned out its because I didn't have time to search the internet for the path. Alternatively, just a big button for "external SD card" (since my Galaxy S3 has an internal, confusing SD card as main memory)
2) I know this isn't your fault, but a work around to keep the volume at its setting from last time would rock. Android (4.x) takes volume to ~60% whenever you start an audio program, then you have to go back and turn it up manually. EACH TIME. Uhg. :-)
AbeFM
Postby daneren2005 » Tue Jun 18, 2013 9:06 pm
Yah I keep meaning to look into making the cache location browseable instead of requiring you to type it. As for the second one I don't think that is a Android thing, but another one of Samsung's convenient "features" ;)
Postby Mr. Odd » Mon Jun 24, 2013 2:38 pm
I like to compile singles into one "album" but I embed the appropriate cover art for each track. Currently, DSub seems to pick one cover and use it for the entire album. It'd be ideal if it could just use the embedded art or each track as it plays. Thanks!
Mr. Odd
Postby daneren2005 » Mon Jun 24, 2013 2:51 pm
DSub uses the artwork that is sent from the server.
Postby mr_nobody » Fri Jul 26, 2013 2:57 am
It would be nice to have an option to hide the Podcasts tab just like we can with the Chat tab. Thanks!
mr_nobody
Postby baziel » Thu Aug 01, 2013 9:55 am
I use Dsub regularly at home and in my car, i would like to start dsub offline and playing while i'm connected via bluetooth in my car.
(mobile data transfer in Belgium = expensive)
I can start dsub (via tasker) when i'm connected, that works fine, but i still have to press buttons.
Would it be possible to give dsub some starting parameters i mean like dsub -offline -play / dsub -pause /dsub -online ?
baziel
Postby daneren2005 » Thu Aug 01, 2013 3:43 pm
I'm not really sure how tasker works to be honest. I will have to look into how it passes parameters.
Postby GJ51 » Fri Aug 02, 2013 2:58 am
Tasker was unquestionably the best Special teams player ever to have played the game.
http://en.wikipedia.org/wiki/Steve_Tasker
Postby rmnma » Tue Aug 06, 2013 7:13 pm
When I have starred a song in musiccabinet, the song appears in the starred tab of Dsub. When I go to an album with a starred song in it, there is no blue star by the song. Is it possible for you to fix this, because when I listen to an album I don't know if I have starred a song earlier?
rmnma
Postby daneren2005 » Tue Aug 06, 2013 8:03 pm
I just verified that it happens and there is nothing I can do about it. I get the stars with the rest of the song info so if the server doesn't specify it the app doesn't know if it is starred or not. And some hakko disappeared there will probably never be a fix.
Return to DSub for Android
