Feature Requests
Re: Feature Requests
Postby daneren2005 » Mon Mar 24, 2014 2:26 pm
Alright, then you must be getting a different error. Do you mind creating me a temp username/password for me and PMing or emailing it to me? I've found it's the fastest way to resolve these types of issues instead of me just trying to guess what it might be.
PS I'm really not sure why you guys are remembering there being a Show Artist button on the now playing screen. I don't remember it ever being there and I certainly wouldn't just taken it out because I was bored. And it would have had the same technical limitations that what I am doing now has. Before what I did have was that when you did Show Album, it automatically added the artist to the back stack, so when you pressed back it went to the artist instead of the library screen. I changed it to what it does now because some people didn't like that. But even then, when you were playing from a playlist it didn't do that because that information just wasn't available then.
Postby peioe » Fri Apr 18, 2014 8:27 pm
Sorry if this has been suggested before but I started using DSub a few days ago and I had this idea. I set it up to use my micro sd card for the cache and I was wondering if it'd possible to use both the internal memory AND the sd card. I have 16GB internal memory on my SGS3 and it's mostly unused so using it too would be awesome. If it's too complicated nvm, the app is already pretty awesome as is :)
Thanks !
peioe
Postby daneren2005 » Fri Apr 18, 2014 9:16 pm
I'm probably not going to do that. No because it's not a good idea, but because the number of people it would benefit is so small that at this point there are just a ton of other things I would rather work on. My TODO list is already big enough as it is ;)
Postby peioe » Fri Apr 18, 2014 10:06 pm
No problem :) Thanks for the app :)
peioe
Previous
Return to DSub for Android
