Updated Playlists
Updated Playlists
Postby dewd » Fri Sep 06, 2013 1:14 am
Sorry if this has been discussed. I am not allowed to search for the word "playlist" because it is too common. :shock:
I created a playlist on the server (Madsonic) and accessed it on the phone(version 4.14). I copied all of the songs to my phone. Later I added additional songs to the playlist on the server. It does not update on the phone. I tried refreshing it several times and confirmed it is correct on the server.
Can you make it sync with the server? Or is it Madsonic causing the problem.
Thanks.
EDIT: It is Madsonic 5.0.3600.beta5
dewd
Re: Updated Playlists
Postby daneren2005 » Fri Sep 06, 2013 5:33 am
Madsonic might not be correctly duplicating the changes to the app. When you click refresh in the app they don't show up? What about if you go menu -> exit, then go back and look at it again?
Postby dewd » Fri Sep 06, 2013 2:35 pm
GRRRRR!!! Never mind. I was in offline mode. :oops:
When online it works as expected. I will go stand in the corner for 30 minutes for being a stupid.
Thanks again for a great app.
dewd
Return to DSub for Android
