Play Store Beta
Re: Play Store Beta
Postby SenorSmartyPants » Tue Sep 22, 2015 6:46 pm
When I have a podcast episode cached and I go offline, the podcast top level item is empty. But if I go to the library there is a podcast item and the podcasts are listed in there.
SenorSmartyPants
Re: Play Store Beta
Postby daneren2005 » Tue Sep 22, 2015 10:21 pm
Does it only happen with one podcast or with all of them? I just tried a couple and they showed up.
Re: Play Store Beta
Postby SenorSmartyPants » Tue Sep 22, 2015 10:29 pm
I only have one podcast setup.
SenorSmartyPants
Re: Play Store Beta
Postby daneren2005 » Tue Sep 22, 2015 10:33 pm
Can you try adding another to see if that takes care of it?
Re: Play Store Beta
Postby daneren2005 » Wed Sep 23, 2015 8:33 pm
Or even share the url of that podcast. If it has any special characters in it that might have been why it failed to save it for offline.
Re: Play Store Beta
Postby SenorSmartyPants » Wed Sep 23, 2015 9:32 pm
No special characters other than ? and =
I can't share it as it is a premium link that I am paying for.
SenorSmartyPants
Re: Play Store Beta
Postby williamkray » Mon Nov 09, 2015 7:20 am
on the latest beta, i received a notification that a podcast i have set to "sync" had a new episode available, but it had not actually been cached. i had to cache it manually. i will disable and enable sync again on some other shows , and see if that works.
williamkray
Re: Play Store Beta
Postby daneren2005 » Tue Nov 10, 2015 7:21 pm
williamkray wrote:on the latest beta, i received a notification that a podcast i have set to "sync" had a new episode available, but it had not actually been cached. i had to cache it manually. i will disable and enable sync again on some other shows , and see if that works.
The sync is functioning correctly. The problem actually stems from the recent episodes. The recent episodes were not generating the correct file path, and that incorrect path was being cached for when viewing the podcast listing as well. Ironically it was only the sync which was caching correctly. Thanks for catching this it will be fixed in the next Beta.
Re: Play Store Beta
Postby daneren2005 » Thu Nov 12, 2015 3:34 am
A beta out with fixes for the stuff mentioned
Re: Play Store Beta
Postby daneren2005 » Fri Oct 09, 2020 4:38 am
Releasing first BETA in quite a while. I know a crap ton of people are having general issues, and this only fixes some of them. As long as it isn't introducing any NEW issues I'm not going to be delaying the release for more bug fixes.
Previous
Return to DSub for Android
