is Airplay an option?
Postby boognish43 » Mon Dec 30, 2013 12:52 pm
Ive recently been using an appletv to play all my videos and music from my ipad/pc/android and was wondering if built in airplay support would be possible in dsub.
I am able to use apps like AirAudio https://play.google.com/store/apps/deta ... u.airaudio to send the audio to the atv but it doesnt always work and Im wishing it was built into the music app.
From what I understand airplay was opened up recently to allow developers to use it but I havent seen it built into many android apps so Im not sure if this is even possible.
boognish43
Re: is Airplay an option?
Postby daneren2005 » Mon Dec 30, 2013 3:47 pm
It's on the todo list. No idea when I will get to it though. It's not like it's a simple thing to do and I have a lot of things ahead of it to do first. I don't think it was opened up, I think someone just made a library for devs to use in their apps.
Postby boognish43 » Mon Dec 30, 2013 5:59 pm
daneren2005 wrote:It's on the todo list. No idea when I will get to it though. It's not like it's a simple thing to do and I have a lot of things ahead of it to do first. I don't think it was opened up, I think someone just made a library for devs to use in their apps.
Thanks for the response. I am glad to see its on the list, I will be patient :)
boognish43
Postby huladaddy » Fri Jun 26, 2015 5:06 am
Any update on airplay support? :)
huladaddy
Postby daneren2005 » Fri Jun 26, 2015 8:59 pm
Still no intention on doing it any time soon.
Postby alphawave7 » Fri Jun 26, 2015 10:09 pm
FWIW, Allstream from Kinetics does a great job of this to my Pioneer wireless speakers, either dlna or airplay..also does Chromecast.
Return to DSub for Android
