Chromecast Support
Re: Chromecast Support
Postby HerrNilsson » Mon Apr 07, 2014 2:16 pm
trogdan wrote:
HerrNilsson wrote:But LDAPS is only for encrypting the credentials from the subsonic server and LDAP-server, the webinterface in encrypted through the HTTPS correct?
Yeah, only the web interface is encrypted through the HTTPS connection. I just happen to use LDAPS because it's used for other service outside of my local network.
The REST and web interface is encrypted through HTTPS.
Yes but i mean if you have HTTPS and LDAP (not LDAPS) and logon through a public site. The credentials are sent to the webserver over HTTPS.
Then in cleartext from the webserver to the LDAP-server. That's not a problem in most cases because it is sent internally in the network :).
HerrNilsson
Postby trogdan » Mon Apr 07, 2014 2:24 pm
HerrNilsson wrote:Yes but i mean if you have HTTPS and LDAP (not LDAPS) and logon through a public site. The credentials are sent to the webserver over HTTPS.
Yeah, I understand that is your configuration, I was not meaning to imply that LDAP goes over the external network unencrypted. Was merely explaining that I said I use LDAPS because I use it externally, unlike your configuration, which should also be safe. (As long as you are not allowing guests on your internal network that could sniff other people's credentials).
trogdan
Postby HerrNilsson » Mon Apr 07, 2014 2:56 pm
Exactly :).
HerrNilsson
Postby daneren2005 » Mon Apr 07, 2014 6:40 pm
This is a long shot, but are either one of you willing to try Subsonic without LDAP, but still on https and see if it connects that way? I doubt LDAP would be the issue, but since you are both using it and it is a problem for you, I figured it would be worth a try.
Postby HerrNilsson » Tue Apr 08, 2014 1:09 pm
I tried to connect with HTTPS with a local account on my subsonic server. Same problem :(.
HerrNilsson
Postby daneren2005 » Wed Apr 09, 2014 2:34 pm
If anyone else has this problem with a valid certificate, just send me a email for a updated apk until I do the next release.
Postby HerrNilsson » Thu Apr 10, 2014 7:06 am
daneren2005 wrote:If anyone else has this problem with a valid certificate, just send me a email for a updated apk until I do the next release.
Do you have an apk that might work? In that case i'd be happy to try it out.
HerrNilsson
Postby daneren2005 » Thu Apr 10, 2014 2:44 pm
Yes I fixed an issue with people who are using valid certificates.
Postby HerrNilsson » Thu Apr 10, 2014 3:01 pm
daneren2005 wrote:Yes I fixed an issue with people who are using valid certificates.
StartSSL is a valid certificate i guess?
Would it be possible to test the new apk with my setup?
HerrNilsson
Postby daneren2005 » Thu Apr 10, 2014 6:21 pm
Yes, StartSSL is a valid cert. Send me a email and I can give it to you.
Postby HerrNilsson » Fri Apr 11, 2014 9:04 am
Done. Thanks mate!
HerrNilsson
Postby daneren2005 » Fri Apr 11, 2014 4:08 pm
I never got any email. Should be at dsub.android@gmail.com
Postby HerrNilsson » Fri Apr 11, 2014 7:25 pm
I've sent another one. Spam folder? :)
Otherwise PM might work?
HerrNilsson
Postby daneren2005 » Fri Apr 11, 2014 7:57 pm
I logged into that account and checked the spam folder, and no dice. Gmail is sending into the nether. I guess pm your email and I can email it to you (I can't attach it here because it's more than 2MB).
Postby HerrNilsson » Fri Apr 11, 2014 8:56 pm
daneren2005 wrote:I logged into that account and checked the spam folder, and no dice. Gmail is sending into the nether. I guess pm your email and I can email it to you (I can't attach it here because it's more than 2MB).
Alright, thanks!
HerrNilsson
Return to DSub for Android
