(Closed) $50 Developer Bounty
Postby daneren2005 » Sat Feb 15, 2014 11:53 pm
Alright, I'm at my wits end with this and it is fairly important to have this working for the release of Chromecast support. I need to be able to detect and block the standard volume key presses while outside of the app and when using a remote media player (either ChromeCast or Jukebox). I have found a couple of hacky ways to detect when the volume is changed outside of the app, but I can't figure out how to stop the default volume action from happening. It's pointless to be able to change the volume if you are also doing something unintended such as changing the ringer volume. Things I have tried so far:
Listening in the registerMediaButtonEventReceiver event. Volume keys don't seem to go through here at all.
ContentOberserver
Defining a custom broadcast receiver that listens for android.media.VOLUME_CHANGED_ACTION. Broadcast is not ordered though so it can't be cancelled.
I need this to work and I can't figure it out. I know it is possible because Play Music does it while casting just fine. I don't even need you to plug in all of the actual logic behind it, I just need a concrete way to both get which volume key was pressed, and to block the default system volume change while not in the activity. I am offering a $50 bounty for a fix to this issue, paid via Paypal.
Re: $40 Developer Bounty
Postby daneren2005 » Sun Feb 16, 2014 12:18 am
Also willing to give partial bounties to anyone who gives just gives me information that leads to a working solution
Postby Fenny » Wed Feb 26, 2014 6:31 pm
Looks like the latest pandora works. (Volume changes on the device, but it is the media volume) I'll reverse their implementation if I have a moment later today.
Fenny
Re: $50 Developer Bounty
Postby daneren2005 » Wed Feb 26, 2014 6:40 pm
I sure hope you are able to. I just upped the bounty to $50...don't know why I had it at a weird number like 40 to being with.
Postby oggie » Sat Mar 01, 2014 5:54 pm
Is this related to the fact that whenever I start a chromecast, the volume is always at 100%? Even if the last time I connected I dropped it down only to have it at 100% again the next time?
oggie
Postby daneren2005 » Sat Mar 01, 2014 6:07 pm
No that is another issue. I can probably craft a work around for that but there is a ticket open for Google to fix that.
Postby Fenny » Sun Mar 09, 2014 3:15 am
I have a workaround in mind. It involves playing a silent audio file locally on the device, and whenever media volume changes we push the new volume to the chromecast.
This solution would be pretty hackish, but it would certainly do the trick. I think we could create a silent PCM or wave stream easily enough, and with whatever length we require to match the length of the media playing on the chromecast for that matter.
Fenny
Postby daneren2005 » Fri Apr 25, 2014 2:35 am
Turns out this was stupidly trivial to do. I found the answer while deep diving the source code for the CastCompanionLibrary example Google has up. All you have to do is register the RemoteControlClient to the MediaRouter in use.
Return to DSub for Android
