Bluetooth Radio playback freezes in dSub version >= 4.5.6
Postby caveet » Thu May 01, 2014 8:43 pm
When using dSub in my car via Bluetooth, playback sometimes freezes at the start of a song. This happens about half of the time, and seems to be random. It is always during the first two seconds of a song.
I have experienced this issue with versions 4.5.6 and 4.5.8. I rolled back to version 4.5.5 and stopped having this problem. Just by looking at the changelog, I'm guessing the issue might be "Work around for Samsung's bluetooth metadata for 4.3+ devices"... maybe adding a toggle to disable this in the settings would help?
Phone: LG G2 D800 w/ stock rooted Kitkat 4.4.2
Car: Toyota Highlander 2012
Note - on all versions of dSub that I've tried, bluetooth metadata occasionally disappears on this car's radio. I don't know if that is relevant or not.
caveet
Re: Bluetooth Radio playback freezes in dSub version >= 4.5.
Postby ecd1973 » Tue May 06, 2014 7:30 pm
caveet wrote:When using dSub in my car via Bluetooth, playback sometimes freezes at the start of a song. This happens about half of the time, and seems to be random. It is always during the first two seconds of a song.
Having the same issue in a Toyota Sienna 2011. Song plays fine, the next song plays for 10 seconds then the audio drops out (but song is still playing in DSub).
ecd1973
Postby daneren2005 » Thu May 08, 2014 2:21 am
Well, we can try it out here. This apk is the same as what is in the play store (4.6.3), except with the Samsung bluetooth fix reverted. Let me know if this one no longer has that issue.
Postby caveet » Sat May 10, 2014 1:07 am
Yep - that fixes it! I just used this version non-stop on a 2 hour drive, and did not experience any freezes.
caveet
Postby daneren2005 » Wed May 14, 2014 2:09 pm
Alright, here is another version that only uses the work around when the phone is a Samsung phone. Can you check to make sure the check works correctly.
Postby caveet » Fri May 16, 2014 11:24 am
Nope... the problem is back with this version.
Sent from my LG-D800 using Tapatalk
caveet
Postby daneren2005 » Sat May 17, 2014 2:51 am
Alright, here is another version to try. This time I'm doing the check lower down so there should be no way it is still getting called when not on a Samsung phone.
Postby caveet » Sun May 18, 2014 9:50 pm
Strangely, I'm still having the problem on this version... still using the same non-samsung phone
caveet
Postby caveet » Sun May 18, 2014 11:44 pm
Actually... I need to retest. After switching back to the first apk you provided, the Bluetooth freeze is still happening... even though it had worked before. I'm going to uninstall and then reinstall dSub instead of just updating. Will then retest and post the results.
caveet
Postby daneren2005 » Mon May 19, 2014 12:13 am
Did you save the first apk? I overwrote it with the newer ones so if you tried to go back and download it again you weren't actually getting the first one
Postby caveet » Wed May 21, 2014 1:45 pm
I had saved all the apks but may have mixed them up. After deleting them all and starting fresh, the latest apk still has the issue- Bluetooth has frozen twice in an hour of use.
caveet
Return to DSub for Android
