DSub registered as media player?
Postby mikes » Sun May 04, 2014 6:30 pm
DSub 4.6 isn't found by Media Button Router (Play store - used to select which media app bluetooth buttons are sent to). All my other media apps are found (including the Subsonic app, if installed).
I'm guessing that this might be because DSub doesn't properly register itself as a media player or ???
Bluetooth buttons do work with it, as long as I start it running first.
mikes
Re: DSub registered as media player?
Postby mikes » Sun May 04, 2014 7:46 pm
Did a bit of research...
Here's what's expected: https://code.google.com/p/media-button- ... tail?id=16
Looking at the DSub source, and comparing it with some old Subsonic source (https://github.com/haxzamatic/Subsonic- ... nifest.xml), and other nearby entries, it looks like the action below should be enclosed in intent-filter tags... (BluetoothIntentReceiver included for comparison):
        <receiver android:name="github.daneren2005.dsub.receiver.MediaButtonIntentReceiver">
         <action android:name="android.intent.action.MEDIA_BUTTON" />
        </receiver>
        <receiver android:name="github.daneren2005.dsub.receiver.BluetoothIntentReceiver">
            <intent-filter>
                <action android:name="android.bluetooth.a2dp.action.SINK_STATE_CHANGED"/>
            <action android:name="android.bluetooth.headset.profile.action.CONNECTION_STATE_CHANGED"/> <!-- API Level 11 -->
            <action android:name="android.bluetooth.device.action.ACL_CONNECTED"/>
            <action android:name="android.bluetooth.device.action.ACL_DISCONNECTED"/>
            </intent-filter>
        </receiver>
But, I'm a tyro, I could be wrong. But I think that's it, according to http://developer.android.com/guide/topi ... ement.html , a receiver can contain an event-filter or meta-data and the intent-filter must contain the actions.
mikes
Postby daneren2005 » Sun May 04, 2014 9:54 pm
Yes, I meant to just remove the priority but it looks like I accidently removed to whole intent filter. I will fix it in a release tomorrow probably since I won't be at my computer until late tonight.
Postby mikes » Sun May 04, 2014 10:05 pm
thx. I just sent a pull request with the change.
mikes
Return to DSub for Android
