dsub does not seem to be sharing all my songs
Postby mbu10 » Thu May 15, 2014 2:51 pm
Good morning
i have about 400 songs which are cached
and i have it set so will share with other apps, ie google play double twist etc etc
but it does not seem to share all my songs for some reason
i few songs (ones that i have found) that are cached,
can play them in dsub
but when i go into google play
i search for them cannot find them , neither can double twist lots of other songs are there just some of them are not
any idea?
mbu10
Re: dsub does not seem to be sharing all my songs
Postby mr_nobody » Thu May 15, 2014 4:39 pm
Has the android media indexer run since the files arrived on the phone? You can force this by rebooting your phone.
As an aside, I'm not sure that checkbox (hide from other apps or whatever it is) actually ever worked. I don't think it's the dsub dev's code, it was in the original android client. I would have thought checking it would put a .nomedia file in the subsonic directory. I've always had it checked but recently started using google play music and it was showing all my subsonic cache. I manually put a .nomedia file in the directory and they went away.
mr_nobody
Postby daneren2005 » Thu May 15, 2014 5:11 pm
I just took a look, and I saw a pretty huge flaw. The .nomedia file is only created in the unchangeable app folder which is under Android/data/github.daneren2005.dsub/files/, not in the music folder (the one you can manually configure). That is a easy fix. As for the other issue, I am wondering the same thing mr_nobody is asking. How recently did you download them all?
Postby mbu10 » Thu May 15, 2014 6:16 pm
Well just in case I deleted them all and downloaded them all again just before I posted Here
mbu10
Postby mr_nobody » Thu May 15, 2014 8:16 pm
Fine but did you reboot your phone or otherwise force media scanner to run after that? ;)
mr_nobody
Postby mbu10 » Thu May 15, 2014 9:28 pm
Yes. As I knew that Google play only picks up after a restart.
Have restarted again and about 60 songs in there but have synced nearly 400 to the device
And they are there cached as I am currently playing them in offline mode in dsub at the moment.
I will just live with only be able to play in dsub and not be able to edit a music track to create a ring tone
mbu10
Postby mr_nobody » Thu May 15, 2014 11:48 pm
That's pretty weird. Can you notice anything different between the tracks that are visible and that aren't? (different file formats, etc.) Are you using any weird transcoding settings? I'm pretty much out of ideas...
mr_nobody
Postby mbu10 » Fri May 16, 2014 9:10 am
Good morning
As far as i can tell they are all standard mp3 with 128-320 kps encoding nothing out of the ordinary.
i have cleared and downloaded everything again but still no luck
mbu10
Postby daneren2005 » Mon Jun 09, 2014 9:36 pm
I think I figured out why this probably isn't working for you. It seems to only be adding music which is pinned to the MediaStore service. I will have it fixed to add music which is not pinned as well, though it will show as song.complete.mp3 instead of song.mp3 for legacy reasons (and will continue to be so for the foreseeable future).
Return to DSub for Android
