Can't stream via 4G since last dSub update
Postby Mike Marrone » Thu Jun 19, 2014 1:09 am
Following the last dSub update I have been unable to stream via 4G... everything connects and it still works whenever I'm connected to WiFi... but will not stream on 4G. My daughter has the same exact phone and hers works fine. I have checked and rechecked all of my settings (i.e. only play when connected to wi-fi) and have been using this setup for years. Just to make sure I uninstalled and reinstalled the app. I also downloaded iSub and had the exact same problem. It appears to me this is a phone issue but I was wondering if anyone could offer some constructive feedback. The phone is a Samsung SGH-1337 running Android 4.4.2
Thanks in advance.
Mike
Mike Marrone
Mike Marrone
Re: Can't stream via 4G since last dSub update
Postby daneren2005 » Thu Jun 19, 2014 1:56 am
If you are also having trouble with iSub, then it isn't a phone issue since that is a iOS app so would have to be having trouble with two completely different phones. A thousand people have had this issue but everyone seems to just come back and say they fixed it without ever really explaining what was wrong in the first place so I can't help you there :?
Postby GJ51 » Thu Jun 19, 2014 2:49 am
Check your port forwarding. Go to http://canyouseeme.org and verify that the Subsonic port is open. 4040 unless you changed the default.
Postby Mike Marrone » Thu Jun 19, 2014 2:55 am
I'm sorry... my bad. It wasn't iSub it was the regular Subsonic Android mobile app... so it is not an iOS app. However, I just DL's Ultrasonic and that was streaming on 4G... I am very confused. And the port forwarding is fine. Simply can't stream on anything other than Wi-Fi with dSub and the Subsonic app.
Mike Marrone
Mike Marrone
Postby GJ51 » Thu Jun 19, 2014 3:01 am
Did you try the Subsonic demo site?
Postby daneren2005 » Thu Jun 19, 2014 5:04 am
Are you sure you put in the settings the exact same? Same URL, same port and everything?
Postby NightWatcher » Thu Jul 03, 2014 7:59 pm
Same Probleme here. No Problems in Wifi. But could not stream on 3G.
He is trying to downloa the Music in Cache Folder. There are all files as mp3 but could not be playback with all players (eg. Google Music). I think the files are broken on 3G. Resync on 3G issn't a Problem.
NightWatcher
Postby NightWatcher » Thu Jul 03, 2014 8:06 pm
Problem found for me. I have Problems in Transcoding. With unlimited bitrate, I have no problems in 3G.
NightWatcher
Postby Mike Marrone » Fri Jul 04, 2014 3:57 am
It has worked perfectly transcoding for years, this all started in the last 3-4 weeks. Is there a fix, other than streaming without transcoding?
Mike Marrone
Mike Marrone
Return to DSub for Android
