Folder selection
Folder selection
Postby mikes » Tue Jun 24, 2014 1:27 am
In the Subsonic web interface, one is allowed to limit selections to a specific media folder (you can choose "All Folders," or a specific one). Any chance of DSub supporting this? (I've looked, and didn't find anywhere obvious this is supported).
mikes
Re: Folder selection
Postby rubbersoul » Wed Jul 09, 2014 2:34 am
scroll to the very top in library view. it is a drop down selection to choose which folder to view
rubbersoul
Postby mikes » Tue Jul 15, 2014 6:33 pm
In library view, I can select "DSub" (opens pop-out menu to select other views), shuffle or search. No dropdown to select a folder.
Note that I'm talking about media folders, NOT different servers, which can be selected from the home screen.
mikes
Postby daneren2005 » Tue Jul 15, 2014 6:38 pm
If you are browsing by tags there is no way to, and there never will since the server doesn't support it.
Postby mikes » Wed Jul 16, 2014 12:50 pm
That's it! thanks.
mikes
Postby mad1993max » Mon Aug 11, 2014 1:34 pm
Hi the option to change the folder at the top op the library list is suddenly gone after update to 4.7.4? has it moved or is it completely gone?
mad1993max
Postby daneren2005 » Mon Aug 11, 2014 6:18 pm
I did not remove it. As I mentioned earlier in the thread, make sure you do not have Browse By Tags set or it will not show. If it is not set and the folder still does not show, the install may have been corrupted. If that is the case, a reinstall should fix the issue.
Return to DSub for Android
