Has anyone else noticed a problem with version 4.7.3 when the system pauses the music for any reason? In my case, the music jumps back in the song when it's resumed. In addition, the progress bar gets off when this happens because it doesn't move back when the music does.
For instance, if playing a song and at two minutes in, someone calls. After the call, the song resumes playing but at 30 seconds into the song. However, the progress bar thinks the song is still at two minutes. The progress bar will fill up to 100%, and the current time counter will keep going until the song ends, so that (in this case) it will be 1:30 longer than the song length shown on the right of the progress bar.
I've also noticed this version gets in the multiple song playing problem much more readily.
I'm using a Samsung S3 with 4.4.4 CM based ROM.
