Delete songs from playlist?
Postby ar9 » Wed Sep 24, 2014 4:30 am
Is this possible? My account should have full editing privileges on playlists but I cannot seem to remove songs from playlist (not delete from cache, simply remove teh songs).
Conversely, I can add songs to playlists... am I missing something?
ar9
Re: Delete songs from playlist?
Postby daneren2005 » Wed Sep 24, 2014 5:30 am
Should be an option near the bottom to remove from playlist
Postby ar9 » Wed Sep 24, 2014 11:39 pm
daneren2005 wrote:Should be an option near the bottom to remove from playlist
Strange, I don't have that option anywhere in my playlist views...
ar9
Postby daneren2005 » Thu Sep 25, 2014 4:22 pm
What version of Subsonic are you using? I only show the option if you are allowed to delete something from the playlist, so it won't show up if you are not the owner (ie: public playlist). I may have messed something up for an older version of Subsonic when implementing it.
Postby ar9 » Sat Sep 27, 2014 7:18 pm
daneren2005 wrote:What version of Subsonic are you using? I only show the option if you are allowed to delete something from the playlist, so it won't show up if you are not the owner (ie: public playlist). I may have messed something up for an older version of Subsonic when implementing it.
I'm using 4.7.8.
ar9
Postby daneren2005 » Sat Sep 27, 2014 10:14 pm
Version of subsonic not DSub
Postby ar9 » Sun Sep 28, 2014 11:47 pm
Ohhh...
I use MusicCabinet... old as hell. =S
ar9
Postby daneren2005 » Sun Sep 28, 2014 11:59 pm
Ah OK I can bring up my musiccainet instance and look at what is going wrong. If you want to email me I can give you a fixed version before the next update goes out.
Postby daneren2005 » Mon Sep 29, 2014 10:41 pm
Nevermind, I can't see anything wrong with my instance of MusicCabinet either. Are you using whatever the latest version of MusicCabinet is available? You may need to create me a temp username/password so I can look at the issue directly.
Postby ar9 » Mon Nov 17, 2014 5:57 am
daneren2005 wrote:Nevermind, I can't see anything wrong with my instance of MusicCabinet either. Are you using whatever the latest version of MusicCabinet is available? You may need to create me a temp username/password so I can look at the issue directly.
Still having this issue, I've PM'd you my server/credentials.
ar9
Postby daneren2005 » Tue Nov 18, 2014 5:53 pm
Alright, it should be working for you in the next release. I just enabled it when the id has .m3u in it since only MusicCabinet does that as far as I know.
Postby ar9 » Wed Nov 19, 2014 1:06 am
daneren2005 wrote:Alright, it should be working for you in the next release. I just enabled it when the id has .m3u in it since only MusicCabinet does that as far as I know.
You're fantastic.
Thanks man!
ar9
Return to DSub for Android
