Can't download Podcasts to hear them offline
Postby hodlok » Mon Nov 10, 2014 9:05 am
I can't download podcasts from server to hear them offline. In the app I go online, go to Podcasts, I choose the podcast, then I keep pressed the episode I want to download and I select "Cache". It seems to download it, but then I switch the app offline, and when I go to the podcasts section, I see the podcast name, but then there are no episodes inside
Is it normal or I'm doing something wrong?
hodlok
Re: Can't download Podcasts to hear them offline
Postby daneren2005 » Tue Nov 11, 2014 1:51 am
Can you manually look at the filesystem and see if the file is there?
Postby hodlok » Tue Nov 11, 2014 6:28 am
daneren2005 wrote:Can you manually look at the filesystem and see if the file is there?
There is no audio file. It creates the podcast folder, but inside that folder there is only a .jpg, the albumart.jpg, but no audio
hodlok
Postby hodlok » Wed Jan 14, 2015 9:54 pm
Any news about this? Does someone else have the same problem? Or it's only my problem?
hodlok
Postby daneren2005 » Thu Jan 15, 2015 10:11 pm
Honestly, I could never reproduce and haven't hear of anyone else having the same issue. Can you PM me temp user credentials to your server and I can try doing it myself? I'm thinking it my be something as simple as the name it downloads it to not being the same as it is expected to be. But I need to be able to see what it is doing wrong.
Postby hodlok » Thu Jan 15, 2015 10:56 pm
This afteenoon I unistalled DSub, cleared cache and every file related to DSub. Then reinstalled and set everything again and it seems to work fine now, following the same steps I did before.
It's been something really strange but now it's fine. I'll post here if I have the same problem again
hodlok
Return to DSub for Android
