No Data
No Data
Postby jsonnabend » Fri Dec 05, 2014 3:09 am
Scott -
I have been using Subsonic and your great DSub for years now without a hiccup. Suddenly, my Subsonic server crashed and would not run. I re-installed, but now I get a "no data" error in DSub whenever I try to browse my library in DSub.
Any thoughts?
- Jeff
jsonnabend
Re: No Data
Postby daneren2005 » Fri Dec 05, 2014 6:34 am
Do you have a particular folder selected? It could possibly be that the ids don't match anymore. In fact if you don't clear the cache, you will probably have many problems since the ids so all the songs and the directories won't match what is cached in DSub anymore. The clear cache button is under Settings -> Cache. If you want to keep your music, move the music folder first, then move it back after clearing the cache.
Return to DSub for Android
