Lockscreen controls on cyanogenmod 11
Postby richardap1 » Fri Feb 06, 2015 5:15 pm
Hi new users here. Love the app but it seems that the Lockscreen controls don't appear. I think this maybe due to cm11. Deezer had a similar issue where it worked fine for stock roms but not CM.
PS I did write this on a Google play review ( as I didn't know about this section of the forum) however I have removed it and brought it over here.
richardap1
Re: Lockscreen controls on cyanogenmod 11
Postby richardap1 » Fri Feb 06, 2015 6:35 pm
Seems a reboot has sorted it. Probably should have tried that first. Thanks again for the great app
richardap1
Postby daneren2005 » Fri Feb 06, 2015 6:56 pm
If the only place this is a problem is on a custom ROM, chances are it is something that the custom ROM broke ;). Either way, glad a reboot fixed it.
Return to DSub for Android
