Feature request: to be able to choose one subsonic folder an
Postby titooo » Tue Feb 10, 2015 9:03 am
Hi
When I add folders to subsonic in my computer I usually add one folder per genre as it can be seen in the 1st screenshot
With official subsonic app when I go to
Library then I can select if I want display all the folders added or only one particular folder as it can be in the 2nd screenshot.
With dsub that's not possible and if I go to library I just see the music related all the orders. So when i just want to listen to all the music thar I copied to particular folder I'm forced to use the official app.
Would be possible to add that feature to dsub?
Thank you in advance
titooo
Re: Feature request: to be able to choose one subsonic folde
Postby daneren2005 » Tue Feb 10, 2015 3:49 pm
It's always been there. Do you have browse by tags selected in the settings because that stops the folder selection from showing up
Postby titooo » Tue Feb 10, 2015 9:35 pm
Yes. I had that option enabled.
I disabled and now it works as I wanted :)
Thank you
titooo
Postby mikes » Thu Feb 12, 2015 5:27 am
It's "Reggae," unless Reagge is some new genre I'm not aware of.
mikes
Postby titooo » Mon Feb 16, 2015 5:40 pm
mikes wrote:It's "Reggae," unless Reagge is some new genre I'm not aware of.
Yes it is a new genre. You should listen to it
titooo
Return to DSub for Android
