Request - Don't flash white screen on run
Postby huladaddy » Wed Mar 11, 2015 12:09 am
When DSub is launched for the first time, it flashes a white screen for a brief second. Normally, no big deal, however, I sometimes like to listen to music at night in bed, with my wife sleeping (or drifting off) next to me. I use dark themes wherever possible, including with DSub. But even though I am using a dark theme inside DSub, it flashes a white screen when I run it, and in pitch blackness, it is quite bright. Is this white screen necessary, and if so, could it be changed to black if the user has a dark theme selected?
So, you see, it's not normally a big deal, and even in the situation I described, it's still not a big deal, but it would be nice if it could be addressed.
huladaddy
Re: Request - Don't flash white screen on run
Postby daneren2005 » Wed Mar 11, 2015 1:26 am
Unfortunately there is no way to set change the default splash page that appears before the app is finished launching. I am already changing the theme at the earliest opportunity that the code allows. One thing someone suggested was to use a transparent theme for the default, but that just makes it feel like the app isn't responding when you click the icon. I am playing with changing the default to dark, but that is just as jarring in the opposite direction.
Return to DSub for Android
