Files fully load before play -- is this correct behavior?
Postby madison437 » Sun Apr 19, 2015 11:32 am
I have a question about the streaming behavior when playing files transcoded to flac… for example, I am transcoding ALAC .m4a files to FLAC so that I can play them on DSub.
The transcoding command I’m using is:
ffmpeg -i %s -map 0:0 -v 0 -f flac -
This works, but the only issue I have is that these transcoded files will not play immediately on DSub, even when communicating over my LAN. DSub waits until the file is first fully downloaded before playback. Perhaps this is the same with .mp3s, but it's so quick that I don't notice it.
I don’t, however, have this problem with the standard Subsonic Android app. The files play almost immediately.
Is there anything I can do to optimzie this behavior to make things seem a bit more seamless in DSub?
Many thanks for any help!
— madison437
DSub Version 4.9.5
Subsonic Version
5.2.1 (build 4427) – March 4, 2015
Server jetty-6.1.x, java 1.8.0_25, Mac OS X (61.8 MB / 128.0 MB)
madison437
Re: Files fully load before play -- is this correct behavior
Postby grumpwagon » Tue Apr 21, 2015 7:27 pm
This occasionally happens with podcasts as well (which, as far as I know, aren't being transcoded). Not every time though. It started happening a few releases ago. Maybe early this year? I kept meaning to mention it here and just forgot.
grumpwagon
Return to DSub for Android
