"Not authorized. Check user permissions in Subsonic server."
Postby contraband » Tue May 26, 2015 12:48 pm
I'm attempting to use DSub with an Ampache install on Apache on Ubuntu 14.04 and I'm getting this error when I try to test the connection. I'm finding this message to be rather unhelpful, and was hoping to get some clarification on what exactly it means. "Use SubSonic backend" is enabled, mod_rewrite is working, and configuration override appears to be enabled? Is this a problem with Apache configuration or some Ampache setting?
Thanks a ton,
cb
contraband
Re: "Not authorized. Check user permissions in Subsonic serv
Postby daneren2005 » Tue May 26, 2015 7:30 pm
This is most likely an Ampache setting. If it was an Apache issue, it would be getting a cannot connect error.
Return to DSub for Android
