Can no longer save to SDCard
Postby DGMayor » Thu Aug 13, 2015 12:50 am
Hey, so I've been running an LG G3 with Lollipop for a few months, no issues...Had DSub saving to the SD Card for the cache, also no issues. I did a factory reset yesterday, and now it won't save to the SD Card and no matter where I tell it to save on the SD, it doesn't seem to work...
No matter where I change it to on the SD Card, it tells me it's invalid and defaults to /storage/external_SD/Android/Data/github.daneren2005.dsub/files/music
I created a folder in the rood of the SD Card at /storage/external_SD/Music and it told me it was invalid..
Help? :)
DGMayor
Re: Can no longer save to SDCard
Postby daneren2005 » Thu Aug 13, 2015 5:22 am
I don't understand you just said the default location it reverted to was /storage/external_SD/Android/Data/github.daneren2005.dsub/files/music which is on the SD Card...Basically the only place DSub can save to is /<mountpoint>/android/data/github.daneren2005.dsub/files/music after KK. This is something all apps are constrained by now. The <mountpoint> appears to be /storage/external_SD/, so it should work. If that isn't actually the location of the sd card, then change just the beginning part to whatever the sd card mount point is.
Postby DGMayor » Thu Aug 13, 2015 10:54 pm
It set itself there but wouldn't save. I ended up formatting the sd card again on the phone and it started working again. Is hoping to not have to redownload alp my music but oh well.
DGMayor
Return to DSub for Android
