Decade setting used for classical music
Postby ds47uk » Thu Oct 29, 2015 8:46 pm
I use Subsonic for classical music as well as more recent music, and I like to use the date field for when the piece was composed and not when it was performed. However Subsonic seems not to be able to go back more than 100 years, which makes this impossible to search for music contemporary wioth Beethoven in the 1800's. Is it possible to enable Subsonic to use earlier decades?
ds47uk
Re: Decade setting used for classical music
Postby daneren2005 » Thu Oct 29, 2015 10:02 pm
Sure I imagine there is nothing special about range that Subsonic exposes via the web GUI. I just went with it because it seemed like a sensible range. I will make it so you can go all the way back to 1800
Postby ds47uk » Fri Oct 30, 2015 2:33 pm
Excellent!!
Best go back to about 1600 then we can fit poor old JS Bach in as well!!
ds47uk
Return to DSub for Android
