Need help to cast lossless.
Postby bibelen » Sat Oct 31, 2015 2:37 pm
Hi.
My entire library is ALAC. I want to cast lossless music to my Chromecast. This is the transcoding line I have tried to use: ffmpeg -i %s -v 0 -map 0:0 -c:a flac -f flac -
On DSUB, every song length is misinterpreted so every song skips before it ends.
Does anyone know a solution for this?
bibelen
Re: Need help to cast lossless.
Postby daneren2005 » Tue Nov 03, 2015 12:17 am
I know others have gotten FLAC working locally, but I'm not sure with what transcoding lines. If it is FLAC -> FLAC, you can just turn off FLAC transcoding altogether and IF your device supports FLAC natively it will work. If it does not support it natively no amount of transcoding voodoo is going to fix that. As for casting lossless, take a look at https://developers.google.com/cast/docs/media. While it lists FLAC as a supported codec, it does not list it as a supported container so it might not work in the first place.
Return to DSub for Android
