Feature request (or can it already do this?)
Postby Mycah » Sun Dec 27, 2015 9:18 pm
When I ride in the car, I'd like to have a different library visible depending on who is in the car with me. I thought I could do this with different subsonic server profiles which have different user accounts/configured music folders, and switch at will but it doesn't appear to be the case. You can't enable/disable profiles or switch them from what I can see.
Is there another way to do what I'm trying to do, or a way to switch profiles that I'm missing?
Mycah
Re: Feature request (or can it already do this?)
Postby daneren2005 » Sun Dec 27, 2015 9:31 pm
You can switch accounts. You have to set up separate server entries for each one
Sent from my iPad using Tapatalk
Postby Mycah » Sun Dec 27, 2015 9:50 pm
how do you switch without deleting them? I couldn't figure it out.
Mycah
Postby daneren2005 » Mon Dec 28, 2015 12:33 am
There is a add server button at the bottom of the server settings
Return to DSub for Android
