Stream to Fire TV
Stream to Fire TV
Postby subidibu » Wed Feb 17, 2016 1:00 pm
Hey,
I'm new to Dsub and I'm very impressed, great App. Unfortunately I didn't get it to work to stream to my fire tv. I installed AllConnect on it. AFAIK with AllConnect Google Cast support should work. Anyhow I don't get it to work with the Dsub App.
Or is there a better solution to stream?
subidibu
Re: Stream to Fire TV
Postby daneren2005 » Wed Feb 17, 2016 3:44 pm
I see nothing in AllConnects description which makes you think that having it installed on a device should make it cast able to. All I see is that they claim to be able to cast to everything.
Sent from my iPad using Tapatalk
Postby subidibu » Wed Feb 17, 2016 6:58 pm
OK. Seems I misunderstood it then. Does anyone have a working solution?
subidibu
Postby TheStretchedElf » Sat Apr 09, 2016 8:41 pm
Subfire
TheStretchedElf
Postby acroyear » Sun Apr 10, 2016 8:22 pm
yeah, SubFire is an app I wrote (insert shameless plug :roll: ) for playing your music on the FireTV. Free (though you need the premium license of Subsonic itself to use apps). Supports all browsing methods except 'starred' - playlists, folder structure, album queries (akin to the 'home page'), and artist->album by id3. It plays directly on the TV/Stick, no 'cast' required.
Even works well if you take your stick with you to a hotel - I do that all the time - provided you've opened your ports properly in your home firewall/router.
The only 'bug' I can not really fix is that if you have an unsigned/self-signed SSL cert, SubFire can not talk to that server. This is a limitation on the FireOS platform and there is no workaround other than signing your cert (along with keeping it up or making sure the domain you reference is the domain the cert is authorized for), or going with plain http.
More details at the webpage below.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Return to DSub for Android
