Feature Request- Remove from playlist
Postby c0utta » Sat Mar 26, 2016 2:34 am
Have been using dSub for the last couple of years, even able to get it to work well on a BlackBerry Z30 in the past. You're doing great work.
My feature request is:
- if currently playing a Playlist, provide the ability to remove songs from that particular Playlist
I imagine that there could be an entry "Remove From This Playlist" on the current context menu.
c0utta
Re: Feature Request- Remove from playlist
Postby grumpwagon » Wed Mar 30, 2016 5:17 pm
Is there a way to do this on the web client? As far as I know, the only way to do this is to swipe away the track, then save to a new playlist.
grumpwagon
Postby c0utta » Tue Apr 05, 2016 10:00 am
You are correct - the only way to do this on the web client is to view the playlist and click the [-] on the right hand side. You cannot do this from the active playlist on the web client.
Your idea of saving to a new playlist is a great option, though. Not as intuitive to me at the beginning, but certainly achieves what I want - dSub even uses the name of the current playlist as the default.
Cheers
c0utta
Return to DSub for Android
