Ratings - how do they work?
Postby TheStretchedElf » Sun Apr 10, 2016 7:37 am
I've never really understood the behaviour of the rating thumbs. If I'm listening a track and tap the thumb up it says rating set and the song has 5 stars next to it. If I tap it again it has none. If I tap the thumb down it says rating set (set to what?) and skips to the next track. Is this the correct behaviour?
Is there any way to rate other than 5 stars using the thumbs? My expectation would be that every tap up adds a star and every tap down deducts one, but that isn't the case.
Where are these ratings stored? I can't see them anywhere on the web client.
Lastly, (and this may be more of a question for the subsonic dev rather than dsub) is there any way to sync ratings to somewhere like RateYourMusic?
TheStretchedElf
Re: Ratings - how do they work?
Postby daneren2005 » Sun Apr 10, 2016 2:46 pm
Yes that is the correct behavior. If you thumbs down it sets it to 1 star and skips it. The ratings are stored on the server but the Web GUzi doesn't expose that information anywhere. Yes you can do a full 5 star rating by clicking the button on a song and selecting Set Rating
Sent from my iPad using Tapatalk
Postby TheStretchedElf » Sun Apr 10, 2016 4:32 pm
daneren2005 wrote:Yes that is the correct behavior. If you thumbs down it sets it to 1 star and skips it. The ratings are stored on the server but the Web GUzi doesn't expose that information anywhere. Yes you can do a full 5 star rating by clicking the button on a song and selecting Set Rating
Thanks for the explanation. It just seemed counterintuitive (and I think I was further confused by 1 star ratings not actually showing, so it just looks like no stars).
Have you ever considered making the thumbs increase/decrease the rating rather than absolute 1 or 5 stars?
TheStretchedElf
Postby daneren2005 » Sun Apr 10, 2016 5:20 pm
No. That is completely opposite of every music app I have ever used. 1 star just shows as red.
Postby TheStretchedElf » Mon Apr 11, 2016 6:56 am
daneren2005 wrote:No. That is completely opposite of every music app I have ever used. 1 star just shows as red.
I see. It's not something I've seen before so it seemed odd that you can only rate 1 or 5 stars but nothing in between.
Using the black theme the red highlight for 1 stars doesn't show at all so it just looked blank to me. It isn't very visible in holo either. Is there a reason for not showing 1 star?
TheStretchedElf
Postby daneren2005 » Tue Apr 12, 2016 12:44 am
I am fixing the theme issue. I mostly use the light theme so I didn't notice it doesn't look right on the others. I am not showing the 1-star because I thought it was pointless clutter when the red background works just as well. Obviously that is only true if you can see the red background though.
Return to DSub for Android
