Can't connect over Internet
Postby huladaddy » Thu Apr 14, 2016 8:53 pm
I can't connect to my subsonic server over the Internet anymore, but I can over WiFi. Any ideas?
huladaddy
Re: Can't connect over Internet
Postby daneren2005 » Thu Apr 14, 2016 9:46 pm
You have a firewall not properly configured somewhere. It will be either on the server or on your router.
Postby huladaddy » Thu Apr 14, 2016 11:12 pm
daneren2005 wrote:You have a firewall not properly configured somewhere. It will be either on the server or on your router.
Yah, I've gone through it a million times. I'm running subsonic in a docker on my unraid box, but I'm sure I have everything configured correctly.
huladaddy
Postby insann » Sat Apr 16, 2016 9:26 pm
Need to tell use more about you're config or some logs or something if you want use to help you !
Insann
insann
Postby huladaddy » Fri May 06, 2016 6:08 am
OK. I'll send some log info. What should I be logging?
huladaddy
Postby insann » Sat May 21, 2016 12:56 pm
Send first you're configuration, then send us you're log files ( in /var/subsonic/subsonic_sh.log )
sorry for that late reply ...
if you're not on linux dont know where to find any logs
insann
Postby huladaddy » Sun Jun 19, 2016 12:11 am
subsonic.log
[2016-06-18 16:30:30,907] INFO HsqlDaoHelper - Checking database schema.
[2016-06-18 16:30:32,287] INFO HsqlDaoHelper - Done checking database schema.
[2016-06-18 16:30:32,648] INFO SettingsService - Java: 1.8.0_92, OS: Linux
[2016-06-18 16:30:33,060] INFO PlayerDao - Deleted 2 player(s) that haven't been used after Tue Apr 19 16:30:33 PDT 2016
[2016-06-18 16:30:33,287] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Sun Jun 19 03:00:00 PDT 2016
[2016-06-18 16:30:33,441] INFO UPnPService - Starting UPnP service...
[2016-06-18 16:30:33,546] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Sat Jun 18 16:35:33 PDT 2016
[2016-06-18 16:30:34,017] INFO UPnPService - Disabling UPnP/DLNA media server
[2016-06-18 16:30:34,018] INFO UPnPService - Starting UPnP service - Done!
[2016-06-18 16:30:43,496] WARN NetworkService - No UPnP router found.
[2016-06-18 16:30:44,027] INFO BootstrapVerificationFilter - Servlet container: jetty-6.1.x
[2016-06-18 16:30:52,696] INFO VersionService - Resolved local Subsonic version to: 6.0.1
[2016-06-18 16:30:52,706] INFO PlayerDao - Created player 3.
[2016-06-18 16:30:53,059] INFO VersionService - Resolved latest Subsonic final version to: 6.0.1
[2016-06-18 16:30:53,059] INFO VersionService - Resolved latest Subsonic beta version to: 6.1.beta1
[2016-06-18 16:31:12,945] WARN NetworkService - No UPnP router found.
[2016-06-18 16:31:21,364] WARN NetworkService - No UPnP router found.
[2016-06-18 16:31:27,010] WARN NetworkService - No UPnP router found.
[2016-06-18 16:33:08,510] WARN NetworkService - No UPnP router found.
[2016-06-18 16:35:33,545] INFO PodcastService - Starting scheduled Podcast refresh.
[2016-06-18 16:35:33,547] INFO PodcastService - Completed scheduled Podcast refresh.
[2016-06-18 16:44:39,551] WARN NetworkService - No UPnP router found.
[2016-06-18 16:45:23,048] WARN NetworkService - No UPnP router found.
[2016-06-18 16:53:51,081] WARN NetworkService - No UPnP router found.
[2016-06-18 16:54:45,435] WARN NetworkService - No UPnP router found.
[2016-06-18 16:54:53,100] WARN NetworkService - No UPnP router found.
[2016-06-18 17:02:50,634] WARN NetworkService - No UPnP router found.
[2016-06-18 17:03:00,938] WARN NetworkService - No UPnP router found.
[2016-06-18 17:03:05,188] WARN NetworkService - No UPnP router found.
subsonic.properties
#Libresonic preferences.  NOTE: This file is automatically generated.
#Sat Jun 18 17:03:05 PDT 2016
TrialExpires=1468880377781
SettingsChanged=1466294585187
OrganizeByFolderStructure=true
IndexCreationHour=3
FastCacheEnabled=false
ServerId=5449105843608837835
HttpsPort=0
UrlRedirectCustomUrl=http\://####.privatedns.org\:4040
MediaLibraryStatistics=10 24 277 2005582052 62083
PortForwardingEnabled=false
LastScanned=1466288757015
Port=4040
UrlRedirectType=CUSTOM
UrlRedirectionEnabled=true
UrlRedirectFrom=
IndexCreationInterval=1
subsonic_sh.log
147 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@5f184fc6: display name [org.springframework.context.support.ClassPathXmlApplicationContext@5f184fc6]; startup date [Sat Jun 18 16:30:25 PDT 2016]; root of context hierarchy
276 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
752 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@5f184fc6]: org.springframework.beans.factory.support.DefaultListableBeanFactory@3cef309d
770 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@3cef309d: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
811 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /var/lib/tomcat8/webapps/subsonic.war
Extracting webapp to /config/jetty/${buildNumber}
982 [main] INFO org.mortbay.log - jetty-6.1.x
[GC (Allocation Failure)  15360K->4361K(57344K), 0.0116371 secs]
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/var/lib/tomcat8/webapps/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/config/jetty/$%7BbuildNumber%7D/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
[GC (Allocation Failure)  19721K->4953K(57344K), 0.0066206 secs]
[GC (Allocation Failure)  20313K->4810K(57344K), 0.0054867 secs]
3774 [main] INFO / - Initializing Spring root WebApplicationContext
3775 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
3805 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@c730b35: display name [Root WebApplicationContext]; startup date [Sat Jun 18 16:30:28 PDT 2016]; root of context hierarchy
3841 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
3965 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
4052 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
4072 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]
[GC (Allocation Failure)  20170K->6587K(72704K), 0.0104564 secs]
4129 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf.xml]
4151 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf-servlet.xml]
[GC (System.gc())  13447K->7291K(72704K), 0.0173158 secs]
[Full GC (System.gc())  7291K->3200K(72704K), 0.0342598 secs]
4619 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@c730b35]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1ed6388a
5539 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1ed6388a: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,playQueueDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,bookmarkDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,ratingService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,folderBasedContentDirectory,upnpService,lastFmService,sonosService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,localeResolver,loginFailureLogger,net.sourceforge.subsonic.security.SubsonicApplicationEventListener#0,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,sonosEndpoint,sonosHelper]; root of factory hierarchy
5803 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
[GC (Allocation Failure)  33920K->8983K(68608K), 0.0342657 secs]
[GC (System.gc())  35288K->9799K(72704K), 0.0078063 secs]
[Full GC (System.gc())  9799K->8959K(72704K), 0.0589662 secs]
[GC (Allocation Failure)  35583K->12259K(83968K), 0.0540081 secs]
[GC (Allocation Failure)  51171K->14965K(84480K), 0.0218894 secs]
[GC (Allocation Failure)  53877K->18055K(81408K), 0.0232203 secs]
[GC (Metadata GC Threshold)  34508K->20200K(82944K), 0.0203109 secs]
[Full GC (Metadata GC Threshold)  20200K->14981K(86016K), 0.1017356 secs]
11564 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
11572 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
11573 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(int,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
11573 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
[GC (Allocation Failure)  49797K->19294K(84992K), 0.0078269 secs]
[GC (Allocation Failure)  54110K->20289K(85504K), 0.0190744 secs]
[GC (Allocation Failure)  55105K->21193K(86528K), 0.0198594 secs]
13007 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 9231 ms
13298 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
13299 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
13299 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@39a87e72: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Sat Jun 18 16:30:38 PDT 2016]; parent: org.springframework.web.context.support.XmlWebApplicationContext@c730b35
13300 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
13430 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@39a87e72]: org.springframework.beans.factory.support.DefaultListableBeanFactory@5ea4300e
14013 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@5ea4300e: defining beans [leftController,rightController,statusController,mainController,playlistController,playlistsController,importPlaylistController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastChannelsController,podcastChannelController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlayQueueController,changeCoverArtController,nowPlayingController,starredController,searchController,settingsController,playerSettingsController,dlnaSettingsController,sonosSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playQueueController,coverArtController,avatarController,proxyController,statusChartController,userChartController,m3uController,streamController,hlsController,videoPlayerController,externalPlayerController,downloadController,premiumSettingsController,multiController,wapController,restController,dbController,premiumSettingsValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@1ed6388a
[GC (Allocation Failure)  57033K->21251K(86528K), 0.0286646 secs]
[GC (Allocation Failure)  57091K->21506K(86528K), 0.0138704 secs]
[GC (Allocation Failure)  57346K->23341K(81920K), 0.0183217 secs]
15205 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 1906 ms
15242 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
15272 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
15282 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
15308 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[172.17.0.10:9412](local),objID:[0:0:0, 0]]]]
28607 [btpool0-5] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0.116.rc1 on jetty-6.1.x / JDK 1.8.0_92 from Oracle Corporation at
[GC (Allocation Failure)  59181K->28893K(85504K), 0.0234701 secs]
[GC (Allocation Failure)  64221K->33535K(86016K), 0.0446497 secs]
[GC (Allocation Failure)  68863K->39000K(82944K), 0.0677744 secs]
[GC (Allocation Failure)  70744K->38662K(75264K), 0.0640566 secs]
[Full GC (Ergonomics)  38662K->36054K(107008K), 0.2493528 secs]
[GC (Allocation Failure)  67798K->36601K(115712K), 0.0055620 secs]
[GC (Allocation Failure)  67321K->36742K(115712K), 0.0069636 secs]
[GC (Allocation Failure)  67420K->37019K(115712K), 0.0065445 secs]
[GC (Allocation Failure)  67739K->36931K(115712K), 0.0052289 secs]
[GC (Allocation Failure)  67651K->36939K(114688K), 0.0048175 secs]
[GC (Allocation Failure)  67659K->36979K(115200K), 0.0078806 secs]
[GC (Allocation Failure)  67699K->37019K(112128K), 0.0737215 secs]
[GC (Allocation Failure)  67227K->37699K(105984K), 0.0064251 secs]
[GC (Allocation Failure)  67395K->37707K(111104K), 0.0055738 secs]
huladaddy
Postby huladaddy » Tue Jun 21, 2016 8:22 pm
Looks like the issue involves the ROM I am running on my phone. I tried DSub from a different phone (with a different ROM) and I was able to connect with no problem... Finally, something to go on. If you have any thoughts about what might be causing he issue regarding the ROM and it's settings, let me know. I am running CMRemix (a CM derivative) on a Galaxy Note 4.
huladaddy
Postby grumpwagon » Mon Jun 27, 2016 3:59 pm
My suggestion (and I'm not the developer) is that you should stop intentionally breaking your phone and then blaming apps when they don't work.
Sorry if that's harsh.
grumpwagon
Postby huladaddy » Tue Jun 28, 2016 7:24 am
Don't you love tinkering with your hardware and software? Seeing what you can do? Making it do things differently/better than originally designed? Breathing new light into old hardware? It's fun. It's a hobby. I love running into a problem, scratching my head, wrestling with it for a while, then eventually solving it! I learn so much that way.
And no where did I blame anyone (or any app) for anything, but I know that everyone else saw that except for you.
My suggestion for you, since you seem to think it's OK to tell other people what to do, is to stay out of other people's business and keep your mouth shut if you don't have anything constructive to say.
huladaddy
Return to DSub for Android
